Plotting through Core console on 2024 civil 3d
faisalWJ8Y9
Message 1 of 30
faisalWJ8Y9
Edit:
I have since updated the script to have it working in the 2022 version of Civil 3d. However am having issues making it work on the 2024 version. Upon entering the script lines manually in 2024 it seems to work... any ideas please shoot me a response? The new script is below
Hello all
trying to make a script which I can run with core console to plot drawings through cre console by passing the need to open each drawing and close like publish.
At the moment the script works for single layout drawings IE 1 paper space layout and will PDF the drawings. However I want to make it so that the script will pick up that there is 2 layouts in a drawing and pdf them with the naming convention the layout has.
if you have any ideas can you reach out:? script is below
;;---------=={ A1 SAP STD Draft Plot Script }==------------;;
;; Prints to pdf the current drawing by using the ;;
;; drawing name and layout tab value to create the ;;
;; file name. Saves the PDF to the folder listed below: ;;
;; "U:\\pdf location\\" ;;
;; Author: Faisal D ;;
;; Version 2.0 - 17-01-2024 ;;
;; File Name Variables
(setvar "filedia" 0)
(command "cmdecho" "1")
(command "TILEMODE" "0" "PDMODE" "0" "ZOOM" "E" "-OSNAP" "NONE" "wipeout" "f" "off" "TEXTFILL" "1" "REGENALL");command
(setq PDF_PATH "U:\\pdf location\\")
(if (not (vl-file-directory-p PDF_PATH))
(vl-mkdir PDF_PATH))
;; Start FOREACH loop to run through all layout tabs
(foreach layoutname
(lambda ( dict / def l n )
(while (setq def (dictnext dict (null def)))
(if (not (eq "MODEL" (strcase (setq n (cdr (assoc 1 (reverse def)))))))
(setq l (cons n l))
(reverse l)
(cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_LAYOUT")))
(setvar "ctab" layoutname)
;; Start of PLOTS SETTINGS FOR A1 PDF IN COLOUR - SAP
(command "-PLOT"
;Detailed plot configuration? [Yes/No] <No>:
"yes"
;Enter a layout name or [?] <Layout1>:
;Enter an output device name or [?] <AutoCAD PDF (General Documentation).pc3>:
"DWG To PDF.pc3"
;Enter paper size or [?] <ISO A4 (210.00 x 297.00 MM)>:
"ISO full bleed A1 (841.00 x 594.00 MM)"
;Enter paper units [Inches/Millimeters] <Millimeters>:
"Millimeters"
;Enter drawing orientation [Portrait/Landscape] <Portrait>:
"Landscape"
;Plot upside down? [Yes/No] <No>:
"No"
;Enter plot area [Display/Extents/Layout/View/Window] <Layout>:
"Extents"
;Enter plot scale (Plotted Millimeters=Drawing Units) or [Fit] <1:1>:
"1:1"
;Enter plot offset (x,y) or [Center] <0.00,0.00>:
;"0.00,0.00"
"Center"
;Plot with plot styles? [Yes/No] <Yes>:
"yes"
;Enter plot style table name or [?] (enter . for none) <>:
"SAP_A1-A3.ctb"
;Plot with lineweights? [Yes/No] <Yes>:
"yes"
;Scale lineweights with plot scale? [Yes/No] <No>:
"no"
;Plot paper space first? [Yes/No] <No>:
"no"
;Hide paperspace objects? [Yes/No] <No>:
"no"
;name of plot file
(strcat PDF_PATH layoutname ".pdf")
;Save changes to page setup [Yes/No]? <N>:
"N"
;Proceed with plot [Yes/No] <Y>:
"Yes"
;Effective plotting area: 841.00 wide by 594.00 high
;Plotting viewport 1
);command
;; Ends the for each loop
);; Ends the for each loop
;; END OF PLOT SETTINGS FOR A1 PDF IN COLOUR - SAP
(setvar "filedia" 1)
(prompt (strcat "\n:: PDF saves in " PDF_PATH " | \\U+00A9 Faisal D " (menucmd "m=$(edtime,0,yyyy)") " ::\n"))
Replies (29)
Message 21 of 30
paullimapa
O I see what I did which caused that dash.
I had intended to include in your PDF_PATH the drawing name then a dash "-" separating the layout name but I forgot.
Apparently your script does NOT include the drawing name but just the layout name.
Here's the corrected version:
(defun c:PlotAllLayoutsD (/ PDF_PATH)
(command "_.TILEMODE" "0" "_.PDMODE" "0" "_.ZOOM" "_E" "-OSNAP" "_NONE" "_wipeout" "_f" "_off" "_.TEXTFILL" "1" "_.REGENALL")
(foreach x (dictsearch (namedobjdict) "acad_layout")
 (if (and (= (car x) 3)
          (/= (cdr x) "Model")
     (command "_.-PLOT" "_Y" (cdr x) "DWG To PDF.pc3" "ISO full bleed A1 (841.00 x 594.00 MM)" "_M" "_L" "_N" "_E" "1=1" "_Center"  "_Y" "SAP_A1-A3.ctb" "_Y" "_N" "_N" "_N" (strcat PDF_PATH (cdr x) ".pdf") "_N" "_Y")
(princ)
But it's too bad that it still failed with the custom profile.
Curious for your custom profile under AutoCAD Options > Plot and Publish tab do you have Background Plotting checked? I typically leave this unchecked assuming it matters when running Core Console.
Paul Li
IT Specialist
@The Office
Message 22 of 30
faisalWJ8Y9
hmm no it seems in both profiles the publishing option was ticked, but still worked in the default profile.
I think there must be some line of code in the custom profile set by the office that is not allowing permission to run the script. Its the only feasible thing I can think of right now
Message 23 of 30
paullimapa
Some other things I'd try just to rule them are:
1. Don't run this line of code before plotting:
2. Don't set the PDF_PATH to the network but instead to your C: drive & to a folder with no spaces:
(setq PDF_PATH "C:\\pdf\\")
3. Instead of using a custom ctb: SAP_A1-A3.ctb change it to use a standard ctb that comes with AutoCAD like: Monochrome.ctb
Paul Li
IT Specialist
@The Office
Message 24 of 30
faisalWJ8Y9
Yeah I have tried these as well to no effect. The problem persists unfortunately
Message 25 of 30
paullimapa
Very odd....but at least you got it to work in the default profile.
Paul Li
IT Specialist
@The Office
Message 26 of 30
faisalWJ8Y9
yes for the time being, at least I can have the team using it in the default profiles. At the end of the day as long as the ctb files and everything are setup correctly it shouldn't be a problem.
Message 27 of 30
faisalWJ8Y9
Hey Paul,
I'm wondering if you can assist me further... so we know that the plotting through core console works which is great. I've now made an excl sheet, that updates my titleblock attributes. Basically you make the changes and create a csv file, I have another lisp that when the drawing is opened it will update those attributes.
The problem is you have to open the drawing for the command to work, so I'm wondering if you know a way I can update the lisp to make it so I don't actually have to open the drawing for the attributes to update, otherwise it kind of defeats the purpose of having a plot through core console command.
This is the lisp that reads the csv file:
;;-----------------------=={ Update Attributes }==----------------------;;
;; Reads a CSV file containing attribute data, and, should the drawing ;;
;; name of the current drawing appear in the first column of the CSV ;;
;; Drawing List, the program will proceed to update block attributes. ;;
;; The attributes updated will be those with tags corresponding to the ;;
;; CSV column headings. These will be updated with values from the ;;
;; row in which the drawing file is listed. ;;
;; Example of CSV format: ;;
;; | DWG | Layout* | Block* | TAG1 | ... | TAGN | ;;
;; | Drawing1 | Layout1 | Block1 | Value1 | ... | ValueN | ;;
;; | Drawing1 | Layout2 | Block1 | Value1 | ... | ValueN | ;;
;; | Drawing2 | Layout1 | Block2 | Value1 | ... | ValueN | ;;
;; *Layout & Block Name columns are optional. ;;
;; Possible Warnings: ;;
;; - Without a block filter or block name column the code will ;;
;; update ALL attributed blocks with tags listed in the CSV ;;
;; headings. ;;
;; - Currently designed to run on startup - add to either ;;
;; Startup-Suite or ACADDOC.lsp to update blocks when drawing is ;;
;; opened. To disable code running when loaded, remove (c:utb) ;;
;; from the bottom of the code. ;;
;; Author: Lee Mac, Copyright 2011 - www.lee-mac.com ;;
;; Version 1.0 - 2011-01-12 ;;
;; - First release. ;;
;; Version 1.1 - 2011-01-13 ;;
;; - Added optional 'Layout' column (next to DWG Column) to allow ;;
;; multiple titleblocks to be updated with different information ;;
;; within a single drawing. ;;
;; Version 1.2 - 2011-08-28 ;;
;; - Removed case-sensitivity of drawing file column in CSV. ;;
;; Version 1.3 - 2011-12-27 ;;
;; - Revised the code to correctly process CSV files generated using ;;
;; OpenOffice software. ;;
;; Version 1.4 - 2012-01-16 ;;
;; - Updated the 'ReadCSV' local function to correctly read CSV cells ;;
;; containing commas and quotes. ;;
;; Version 1.5 - 2012-09-19 ;;
;; - Updated CSV file parser function to account for the use of ;;
;; alternative cell delimiter characters in CSV file (such as a ;;
;; semi-colon). ;;
;; Version 1.6 - 2013-05-22 ;;
;; - Removed the need for file extension in first column of CSV file. ;;
;; - Updated CSV file parser function to correct bug. ;;
;; Version 1.7 - 2014-11-01 ;;
;; - Fixed bug causing filenames containing ASCII character 46 (point) ;;
;; to not be found in the first column of the CSV file. ;;
;; Version 1.8 - 2015-04-13 ;;
;; - Added support for duplicate attribute tags. ;;
;; - Added support for optional 'Block Name' column in CSV file. ;;
;; - Added inclusion of anonymous block names to optional block name ;;
;; filter to enable dynamic block support. ;;
;; Version 1.9 - 2016-09-18 ;;
;; - Fixed implementation of block filter when processing attributed ;;
;; dynamic blocks. ;;
(defun c:Titleblock_Update
*error*
ano
bln bno
csv
ent
flg fnb:fun
inc
lst
sel str
tag
utb:blk utb:csv utb:ftr utb:lay
val
;; Location of CSV Drawing List (set to nil for prompt) ;;
;; If the CSV file resides in the same directory as the drawing, omit ;;
;; the filepath from the location of the CSV file, and only include ;;
;; the filename, e.g. "myfile.csv" ;;
;; If only a filename is specified, AutoCAD will first search the ;;
;; working directory for this file before searching the Support Paths. ;;
(setq utb:csv "_DRAWING_REGISTER_MULTI.csv") ;; e.g. (setq utb:csv "C:/myfolder/myfile.csv")
;; Block Filter (may use wildcards and may be nil) ;;
(setq utb:ftr nil) ;; e.g. (setq utb:ftr "*BORDER")
;; Layout Column (t or nil) ;;
(setq utb:lay t) ;; set to t if CSV file contains Layout Column
;; Block Name Column (t or nil) ;;
(setq utb:blk nil) ;; set to t if CSV file contains Block Name Column
(defun *error* ( msg )
(LM:endundo (LM:acdoc))
(if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
(princ (strcat "\nError: " msg))
(princ)
(setq fnb:fun
(lambda ( s )
(if (wcmatch (strcase s t) "*.dwg,*.dxf,*.dwt,*.dws")
(vl-filename-base s) s
(cond
( (not (setq sel (ssget "_X" (vl-list* '(0 . "INSERT") '(66 . 1) (if utb:ftr (list (cons 2 (strcat "`*U*," utb:ftr))))))))
(princ "\nNo Attributed Blocks found in drawing.")
( (and utb:csv (not (setq csv (findfile utb:csv))))
(princ
(strcat
"\n"
(vl-filename-base utb:csv)
(vl-filename-extension utb:csv)
" not found."
( (and csv (/= ".CSV" (strcase (vl-filename-extension csv))))
(princ "\nAttribute data file must be in CSV format.")
( (not (or csv (setq csv (getfiled "Select CSV File" "" "csv" 16))))
(princ "\n*Cancel*")
( (not (setq lst (mapcar '(lambda ( x ) (cons (strcase (fnb:fun (car x))) (cdr x))) (LM:readcsv csv))))
(princ
(strcat
"\nNo data found in "
(vl-filename-base csv)
".csv file."
( (not
(setq tag (mapcar 'strcase (cdar lst))
lst (LM:massoc (strcase (fnb:fun (getvar 'dwgname))) lst)
(princ (strcat "\n" (fnb:fun (getvar 'dwgname)) " not found in first column of CSV file."))
( t
(setq lst (mapcar '(lambda ( x ) (mapcar 'cons tag x)) lst)
ano 0
bno 0
(LM:startundo (LM:acdoc))
(repeat (setq inc (sslength sel))
(setq ent (ssname sel (setq inc (1- inc)))
bln (strcase (LM:al-effectivename ent))
val lst
flg nil
(if (or (null utb:ftr) (wcmatch bln (strcase utb:ftr)))
(progn
(if utb:lay
(setq val (mapcar '(lambda ( x ) (cons (strcase (cdar x)) (cdr x))) val)
val (LM:massoc (strcase (cdr (assoc 410 (entget ent)))) val)
(if utb:blk
val (cdr (assoc bln val))
(setq val (car val))
(if val
(foreach att (vlax-invoke (vlax-ename->vla-object ent) 'getattributes)
(if
(and
(setq str (assoc (strcase (vla-get-tagstring att)) val))
(progn
(setq val (LM:remove1st str val))
(/= (vla-get-textstring att) (cdr str))
(progn
(vla-put-textstring att (cdr str))
(setq flg t
ano (1+ ano)
(if flg (setq bno (1+ bno)))
(if (zerop ano)
(princ "\nAll attributes are up-to-date.")
(princ
(strcat
"\n" (itoa ano) " attribute" (if (= 1 ano) "" "s")
" updated in " (itoa bno) " block" (if (= 1 bno) "" "s") "."
(princ)
;; Effective Block Name - Lee Mac
;; ent - [ent] Block Reference entity
(defun LM:al-effectivename ( ent / blk rep )
(if (wcmatch (setq blk (cdr (assoc 2 (entget ent)))) "`**")
(if
(and
(setq rep
(cdadr
(assoc -3
(entget
(cdr
(assoc 330
(entget
(tblobjname "block" blk)
'("AcDbBlockRepBTag")
(setq rep (handent (cdr (assoc 1005 rep))))
(setq blk (cdr (assoc 2 (entget rep))))
blk
;; Read CSV - Lee Mac
;; Parses a CSV file into a matrix list of cell values.
;; csv - [str] filename of CSV file to read
(defun LM:readcsv ( csv / des lst sep str )
(if (setq des (open csv "r"))
(progn
(setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))
(while (setq str (read-line des))
(setq lst (cons (LM:csv->lst str sep 0) lst))
(close des)
(reverse lst)
;; CSV -> List - Lee Mac
;; Parses a line from a CSV file into a list of cell values.
;; str - [str] string read from CSV file
;; sep - [str] CSV separator token
;; pos - [int] initial position index (always zero)
(defun LM:csv->lst ( str sep pos / s )
(cond
( (not (setq pos (vl-string-search sep str pos)))
(if (wcmatch str "\"*\"")
(list (LM:csv-replacequotes (substr str 2 (- (strlen str) 2))))
(list str)
( (or (wcmatch (setq s (substr str 1 pos)) "\"*[~\"]")
(and (wcmatch s "~*[~\"]*") (= 1 (logand 1 pos)))
(LM:csv->lst str sep (+ pos 2))
( (wcmatch s "\"*\"")
(cons
(LM:csv-replacequotes (substr str 2 (- pos 2)))
(LM:csv->lst (substr str (+ pos 2)) sep 0)
( (cons s (LM:csv->lst (substr str (+ pos 2)) sep 0)))
(defun LM:csv-replacequotes ( str / pos )
(setq pos 0)
(while (setq pos (vl-string-search "\"\"" str pos))
(setq str (vl-string-subst "\"" "\"\"" str pos)
pos (1+ pos)
str
;; MAssoc - Lee Mac
;; Returns all associations of a key in an association list
(defun LM:massoc ( key lst / item )
(if (setq item (assoc key lst))
(cons (cdr item) (LM:massoc key (cdr (member item lst))))
;; Remove 1st - Lee Mac
;; Removes the first occurrence of an item from a list
(defun LM:remove1st ( itm lst / f )
(setq f equal)
(vl-remove-if '(lambda ( a ) (if (f a itm) (setq f (lambda ( a b ) nil)))) lst)
;; Start Undo - Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
(LM:endundo doc)
(vla-startundomark doc)
;; End Undo - Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
(while (= 8 (logand 8 (getvar 'undoctl)))
(vla-endundomark doc)
;; Active Document - Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
(eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
(LM:acdoc)
(vl-load-com)
(princ
(strcat
"\n:: S&P UPDATE TITLEBLOCK MULTI.fas | Version 1.0 | \\U+00A9 FAISAL DAVID "
(menucmd "m=$(edtime,0,yyyy) ::\n")
"\n:: Type \"Titleblock_Update\" to run manually ::\n"
(princ)
(c:Titleblock_Update) ;; Remove or comment this line to disable autorun
;; End of File ;;
Message 28 of 30
paullimapa
Unfortunately only certain lisp functions work within coreconsole. So in cases like the complex code you’re running here you may have no choice but to do that the old fashion method of having AutoCAD open the drawing and do the updates, save and close then move on to the next dwg. Do you may have to first complete this task and then run coreconsole separately for plotting
Paul Li
IT Specialist
@The Office
Message 29 of 30
Sea-Haven
"make it so I don't actually have to open the drawing for the attributes to update" you can make Excel the controller rather than Autocad, it can open Autocad and make objects using Excel macros, I guess could open a specific dwg.
Any way here is a draw objects from Excel.
Look at the line in open dwg Set acadDoc = acadApp.Documents.Add maybe do an open instead I have not tested. Nor have I tried going down the Excel modifying attributes but there is really no reason why not just have to know how to get the correct syntaxes for it to work. I have not tried, concentrating more on CAD controlling Excel.
Message 30 of 30
faisalWJ8Y9
Honestly, I am not sure, as I have seen it done at other companies. The problem is that the code is always locked so I can't really assess what I need to edit haha.
