PLOT TO PDF named after attributes
Gaganpatel
Gaganpatel
Dear Sir,
Please modify the attached lisp file
Create PDF from model but the filename of that should be made up from attributes "MARKNO."
created PDF should be named like this T1-1, T1-2, T1-3
ronjonp
Try this:
;;;This is the lisp routine to Plot the material list to individual PDF files with the job name and the page number
;;;as is does in the Plot Material List button.
;;; plotpdf.lsp
(defun c:plotpdf (/ bn cnt dir e i ml mn mx ob ss)
  (vl-load-com)
  (setq cnt 0)
  (setq dir (getvar "dwgprefix"))
  (if
    (and
      (progn (initget "B")
	     (setq ob (entsel "\nSelect Block/B for SS: "))
	     (cond ((eq ob "B") (setq bn (getstring "\nEnter SS: ")))
		   ((and (eq (type ob) 'list)
			 (vlax-method-applicable-p (vlax-ename->vla-object (car ob)) 'getboundingbox)
		    (setq bn (cdr (assoc 2 (entget (car ob)))))
      (tblsearch "BLOCK" bn)
      (setq ss (ssget "_X" (list '(0 . "INSERT") '(410 . "Model") (cons 2 bn))))
     (progn
       (vla-zoomextents (vlax-get-acad-object))
       (repeat (setq i (sslength ss))
	 (setq ml "Material-List")
	 (setq cnt (1+ cnt))
	 (vla-getboundingbox (vlax-ename->vla-object (setq e (ssname ss (setq i (1- i))))) 'mn 'mx)
	 (command "plot"
		  "yes"
		  "model"
		  "DWG To PDF.pc3"
		  "ISO full bleed A4 (297.00 x 210.00 MM)"
		  "inches"
		  "LANDSCAPE"
		  "no"
		  "Window"
		  (trans (vlax-safearray->list mn) 0 1)
		  (trans (vlax-safearray->list mx) 0 1)
		  "fit"
		  "center"
		  "yes"
		  "monochrome.ctb"
		  "yes"
		  "As Displayed"
		  (strcat dir (getpropertyvalue e "MARKNO."))
		  "no"
		  "yes"
		  "yes"
		  "yes"
	 (command ".delay" "750")
     (princ "\nNo Blocks Selected: ")
  (princ)
Gaganpatel
Working is good
Thank you very much sir.
one request possible combine pdf on this lisp ???
ronjonp
@Gaganpatel wrote:
Working is good
No can do sorry. Learn the software and use it as it was designed. This is a task that has been solved OOTB for more than 15 years now ( sheet set manager, publish AND plotting from paper space tabs.
The task at hand was how people were doing this in the 90's. Why is this still a thing?
Sea-Haven
Google Ghostscript yes it can combine pdfs back into 1.
Yes can be done via lisp.
