Placing lips for AutoCAD
EmreYucel34
EmreYucel34
Hello, we want to do Nesting via AutoCAD, is it possible to show a sample Lips? And are there ready-made Lips for this process, thanks in advance for your help, good day
Kent1Cooper
Do some Searching.  This topic has come up before.
[And it's AutoLisp.  "Placing lips" is something one would do in a kiss.]
Kent Cooper, AIA
Moshe-A
@EmreYucel34  hi,
if by saying 'nesting' you mean Recursion, than AutoLISP supports recursion as other top programing languages.
here is a nice example from Mr Lee Mac to return a list from a string.
(LM:str->lst "one,two,three,four" ",") return ("one" "two" "three" "four")
(defun LM:str->lst ( str del / pos )
    (if (setq pos (vl-string-search del str))
        (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del))
        (list str)
LDShaw
This one has two different ways.
It;s running striptext and one that plays with the layers
(c:G-GEN)
(defun c:exl ()
(load "stripmtext.lsp")
(setq all_ss (ssget "x"))
(StripMtext all_ss '("c" "f" "h" "q" "o" "s" "t" "u" "w" "n"))
  (c:G-GEN)
Kent1Cooper
@EmreYucel34 wrote:
.... we want to do Nesting via AutoCAD, ....
Please clarify what you mean.  People are interpreting it differently.  I suspect it is about fitting cut-out shapes most efficiently into sheets of material for minimal waste:
That is from a company that makes nesting software -- www.nestfab.com -- but there are many others.  I don't know about that one, but surely some of them can be used in conjunction with AutoCAD.  A Search in this Forum will probably lead to some.
Kent Cooper, AIA
