A slide is not being displayed in a dialogbox under AutoCAD LT.
HE-MJJ
HE-MJJ
I'm having an issue with a slide not being displayed in a dialogbox. The same slide works fine under the full version but not under LT. Strange thing is, that an older slide from 2005 does get displayed in the dialogbox under LT.
Moshe-A
@HE-MJJ  hi,
Is this a custom slide?
Are you getting error message?
post some pictures of what you are doing.
if an old slide does work, maybe the new version is missing some files?
Moshe
pendean
Community Legend
Community Legend
@HE-MJJ wrote:
...The same slide works fine under the full version but not under LT...
Are you aware LT's LISP is not fully functional like it is in full AutoCAD? It is a limited subset.
Either way, without the full code it's not going to be easy for anyone to help you out with a hypothetical... share please.
HE-MJJ
Solved it. It was a path issue after all.
Moshe-A
@pendean, hi,
Do you know what is the reason 'Autodesk Forums' keep allowing an OP to close his Thread as Solution increasing his own credit?
Moshe
pendean
Community Legend
Community Legend
@Moshe-A wrote:
...Do you know what is the reason 'Autodesk Forums' keep allowing an OP to close his Thread as Solution ...
After many years of OPs to never do much of anything with their own post after creation, the restrictions were removed and more power given to each OP over their own post (short of deleting it).
IMHO a good thing, I'm for OPs doing what they need to do with their own content.
Moshe-A
@pendean ,
by doing that you think this encourage them to close for solution? Can not believe it?! 🤔
