Place circles around blocks
khirunath
Message 1 of 13
khirunath
I have a blocks named DA_LE3 in the drawing and I want to place a circles around them in a single shot. Is anyone have already created a lisp code similar to this requirement? or so any assistance from anyone is greatly appreciated. Thank you.
(Circle radius should be 24 & color blue)
Accepted solutions (3)
Replies (12)
Message 2 of 13
hak_vz
@khirunath
Try this.
(defun c:bcir (/ ss i )
	(setq ss (ssget "X" '((0 . "INSERT")(2 . "DA_LE3"))) i -1)
	(cond
		((and ss)
			(while (< (setq i (1+ i)) (sslength ss))
				(entmake
					(list
						(cons 0 "CIRCLE")
						(cons 100 "AcDbEntity")
						(cons 100 "AcDbCircle")
						(cons 10 (cdr(assoc 10 (entget (ssname ss i)))))
						(cons 40 24)
						(cons 62 5)
	(princ)
Miljenko Hatlak
Message 3 of 13
pbejse
Center of block | Radius 24
(Defun c:BlueCirle (/ Bc i)
  (if (setq Bc (ssget "_X" '((0 . "INSERT") (2 . "DA_LE3,`*U*"))))
    (repeat (setq i (sslength bc))
      (if (eq (strcase
		(getpropertyvalue
		  (setq e (ssname Bc (setq i (1- i))))
		  "BlockTableRecord/Name"
	      "DA_LE3"
	(progn
	  (vla-getboundingbox (vlax-ename->vla-object e) 'll 'ur)
	  (Setq pdata (mapcar '(lambda (p)
			(vlax-safearray->list p)
				 ) (list ll ur)))
	  (Setq mdpt (mapcar (function (lambda (a b) (/ (+ a b) 2.)))
			     (CAr pdata)(cadr pdata)))
		(entmakex (list	(cons 0 "CIRCLE")
				(Cons 10 mdpt)
				(cons 62 5)
				(cons 40 24)
  (princ)
Center of block | Radius size of block
(Defun c:BlueCirle (/ Bc i pdata mdpt rad)
      (if (eq (strcase
		(getpropertyvalue
	      "DA_LE3"
	(progn
				 ) (list ll ur)))
	  (setq rad (distance mdpt (cadr pdata)))
				(Cons 10 mdpt)
				(cons 62 5)
				(cons 40 rad)
  (princ)
HTH
Message 4 of 13
Kent1Cooper
[The suggestions so far use the Block insertion point for the center of the Circle.  If the Block insertion point is not in the center of it, but you want the Circles centered around the Blocks' drawn contents, that can also be done, using their bounding boxes.]
Kent Cooper, AIA
Message 5 of 13
khirunath
Yes you are correct, the Block insertion point is not in the center of it. I need circles to be centered around the block. Both above 2 codes are working fine, but circles are not in centered to block.
Message 6 of 13
pbejse
Of still the same radius? does it depend on the size of the block?
Code updated at post # 3 for rad = 24 and rad = size of block
Message 7 of 13
khirunath
Hi, thanks. Your code is working but circles are not centered to the blocks.
Message 8 of 13
khirunath
Thank you. second one is fine with radius size of block.
Message 9 of 13
hak_vz
Next time attach sample drawing and add detailed description of your problem.
(defun c:bcir (/ ss i a b pt)
	(cond
		((and ss)
			(vlax-invoke-method (vlax-ename->vla-object(ssname ss i))'getboundingbox 'a 'b)
			(setq a (vlax-safearray->list a)b (vlax-safearray->list b))
			(setq pt (mapcar '* (mapcar '+ a b) '(0.5 0.5)))
				(entmake
					(list
						(cons 0 "CIRCLE")
						(cons 10 pt)
						(cons 40 24)
						(cons 62 5)
	(princ)
To add other blocks to selection add them to selection filter
(2 . "DA_LE3,name1,name2")
Miljenko Hatlak
Message 10 of 13
pbejse
Good for you, glad it helps.
Message 11 of 13
khirunath
Hi, Can it be possible to add another block into the same code? or it required separate variables?
Message 12 of 13
pbejse
You can add block names here. [ in blue ]
  (if (setq Bc (ssget "_X" '((0 . "INSERT") (2 . "DA_LE3,`*U*,BLOCK1,BLOCK2"))))
      (if (member  (strcase
		(getpropertyvalue
	      '("DA_LE3" "BLOCK1" "BLOCK2" ))
	(progn
				 ) (list ll ur)))
				(Cons 10 mdpt)
				(cons 62 5)
				(cons 40 rad)
  (princ)
HTH
Message 13 of 13
khirunath
Sure, Thanks
