LISP to add elevation given elevation and number of stairs
Nathan_Tigner
Message 1 of 12
Nathan_Tigner
I am looking for lisp that will ask the user for an elevation and number of stairs, then return 2 pieces of text.
text 1:
SLAB
FFE=(user input elevation + number of stairs*.067)
Text 2:
GARAGE
(number of stairs) STEPS
G=(user input elevation)
Obviously the math is easy, I am just trying to save time as this could be done hundreds of times on any given project. It also could prevent potential user error.
Thank everyone!
Accepted solutions (4)
Replies (11)
Message 2 of 12
pbejse
@Nathan_Tigner wrote:
text 1:  SLAB,  FFE=(user input elevation + number of stairs*.067)
Text 2: GARAGE(number of stairs) STEPS G=(user input elevation)
What is the result for this two input?
0.60 elevation | 4 number of stairs for SLAB prompt ( is that really stairs or steps?)
0.75 elevation  |  5 number of steps for GARAGE ( is the number of steps is from the the SLAB prompt?
Message 3 of 12
Nathan_Tigner
I think I did a bad job of explaining. The bold would be calculated from the 2 user inputs. Everything else is just text.
Text 1:
SLAB
FFE=(ELEVATION + STEPS*.067)
Text 2:
GARAGE
STEPS STEPS
G=ELEVATION
I am trying to end up with something that looks like this
Message 4 of 12
pbejse
Try this demo
(Defun c:demo ( / Elev steps ffe ipnt)
(setq name '("SLAB" "GARAGE"))
  (if (and
	(setq Elev (getdist "\nElevation: "))
	(setq Steps (getint "\nNumber of steps: "))
	(setq ffe ( + Elev (* 0.067 Steps)))
    (foreach itm (list
		   (list (car name)
		       (strcat (car name) "\\PFFE=" (rtos ffe 2 2)))
		   (list (cadr name)
		       (strcat (cadr name)"\\P" (itoa steps) " STEP\\PG=" (rtos Elev 2 2)))
      (if (setq ipnt (getpoint (strcat "\nPick text insertion point for " (Car itm))))
	(entmakex
	      (list
	        (cons 0 "MTEXT")
		(cons 100 "AcDbEntity")
	        (cons 100 "AcDbMText")
	        (cons 10 ipnt)
		'(71 . 2)
		'(72 . 5)
	        (cons 1 (cadr itm))
(princ)
 Command: DEMO
Elevation: 749.08
Number of steps: 1
Pick text insertion point for SLAB
Pick text insertion point for GARAGE
HTH
Message 5 of 12
hak_vz
Try this
(defun c:steps (/ tpe elevation steps ffe pt str st_str)
	(initget 1 "SLAB GARAGE")
	(setq tpe (strcase(getkword "\nslab or garage >")))
	(cond
		((= tpe "SLAB")
		    (prompt "\n___SLAB___")
			(initget (+ 1 2 4))
			(setq elevation (getreal "\nElevation >"))
			(initget (+ 1 2 4))
			(setq steps (getint "\nNumber of steps >"))
			(setq ffe (rtos(+ elevation (* 0.67 steps))2 2))
			(setq pt (getpoint "\nPick text location"))
			(setq str (strcat "SLAB" "\\P" "FFE = " ffe))
		((= tpe "GARAGE")
			(prompt "\n___GARAGE___")
			(initget (+ 1 2 4))
			(initget (+ 1 2 4))
			(if (= steps 1) (setq st_str " STEP")(setq st_str " STEPS"))
			(setq str (strcat "GARAGE" "\\P" (itoa steps) st_str "\\P" "G = " (rtos elevation 2 2)))
	(cond
		((and pt)
			(entmakex
				(list
					(cons 0 "MTEXT")
					(cons 1 str)
					(cons 10 pt)
					(cons 40 (getvar 'textsize))
					(cons 41 0.0)
					(cons 50 0.0)
					(cons 71 5)
					(cons 72 1)
	(princ)
Miljenko Hatlak
Message 6 of 12
Nathan_Tigner
This works perfectly. I did have one question. On some projects I might need a second line in the first text. It would look like:
SLAB
FFE=701.34
FND=701.34
The FND number would be exactly the same as the FFE, So how would I change the lisp so that it would add both FFE and FND?
Thank you so much for the help!
Message 7 of 12
pbejse
Here you go
(initget 1 "Y N")
  (if (and
	(setq Fnd (getkword "\nInclude FND on Text[Yes/No]: "))
    (foreach itm (list
		   (list (car name)
			       (if (eq Fnd "Y") (strcat "\\PFND=" (rtos ffe 2 2) ) "")))
		   (list (cadr name)
	(entmakex
	      (list
	        (cons 0 "MTEXT")
	        (cons 10 ipnt)
		'(71 . 2)
		'(72 . 5)
	        (cons 1 (cadr itm))
(princ)
Command: DEMO
Include FND on Text[Yes/No]: N
Elevation: 12.35
Number of steps: 2
Command: DEMO
Include FND on Text[Yes/No]: Y
Elevation: 23.56
Number of steps: 4
Message 8 of 12
hak_vz
SLAB
FFE=701.34
FND=701.34
Here is modified code for that case. It also takes into account using users coordinate system. Text location is picked so that cursor location represent upper left corner of MTEXT object .
(defun c:steps (/ tpe elevation steps ffe  str st_str a b pt pt2)
	(cond
		((= tpe "SLAB")
			(initget (+ 1 2 4))
			(initget (+ 1 2 4))
			(initget "Yes No")
			(setq fnd(getkword "\nAdd FND (Yes No) >"))
			(if (= fnd "Yes")
				(setq str (strcat "SLAB" "\\P" "FFE = " ffe "\\P" "FND = " ffe))
		((= tpe "GARAGE")
			(initget (+ 1 2 4))
			(initget (+ 1 2 4))
			(setq pt (getpoint "\nPick upper left text corner >"))
	(cond
		((and pt)
			(vlax-invoke-method
				(vlax-ename->vla-object
					(entmakex
						(list
							(cons 0 "MTEXT")
							(cons 1 str)
							(cons 10 (trans pt 1 2))
							(cons 41 0.0)
							(cons 50 0.0)
							(cons 71 5)
							(cons 72 1)
				'getboundingbox 'a 'b
			(setq
				a (vlax-safearray->list a)
				b (vlax-safearray->list b)
				d(mapcar '* (mapcar '- b a) '(0.5 -0.5))
			(command "_.move" (entlast) "" "_non" (trans '(0 0) 1 2) "_non" (trans d 1 2))
	(princ)
Miljenko Hatlak
Message 9 of 12
Nathan_Tigner
You guys rock. Thanks so much for helping me out. Now I just need to figure out how to specify text style and layer.
Message 10 of 12
hak_vz
			(entmakex
				(list
					(cons 0 "MTEXT")
					(cons 1 str)
					(cons 7 "TEXT STYLE")
					(cons 8 "LAYER NAME")
					(cons 10 pt)
					(cons 41 0.0)
					(cons 50 0.0)
					(cons 71 5)
					(cons 72 1)
@Nathan_Tigner
To add layer name and text add i.e change this two lines in my code
Miljenko Hatlak
Message 11 of 12
Nathan_Tigner
Worked perfectly. I was trying to get it to prompt the user for a rotation for the mtext, but I could only get it to work with a static rotation using (cont 50).
Message 12 of 12
hak_vz
@Nathan_Tigner
Check this. Change layer and text style.
(defun c:steps (/ deg_to_rad rotation tpe elevation steps ffe  str st_str a b pt pt2)
	(defun deg_to_rad (deg)(* pi (/ deg 180.0)))
	(cond
		((= tpe "SLAB")
			(initget (+ 1 2 4))
			(initget (+ 1 2 4))
			(initget "Yes No")
			(if (= fnd "Yes")
			(setq rotation (getreal "\nEnter mtext rotation deg <def = 0> >>"))
			(if (null rotation)(setq rotation 0))
		((= tpe "GARAGE")
			(initget (+ 1 2 4))
			(initget (+ 1 2 4))
	(cond
		((and pt)
			(vlax-invoke-method
					(entmakex
						(list
							(cons 0 "MTEXT")
							(cons 1 str)
							(cons 7 "STANDARD")
							(cons 41 0.0)
							(cons 50 (deg_to_rad rotation))
							(cons 71 1)
							(cons 72 1)
			(setq
			(setq ent (entget(entlast)))
			(setq ent(subst (cons 71 5)(assoc 71 ent) ent))
			(entmod ent)
	(princ)
Miljenko Hatlak
