place chainage text at polyline vertex.
Sally_Ward8TWBK
Sally_Ward8TWBK
hello all
I have downloaded a lisp that nearly does what I want. I am hoping to get some help on what to tweak to make it produce what I want.
I dont want
    -the extra 0's in front of chainages with < 3 digits before the decimal point
    -the 01+'s in front of chainages with > 4 digits before the decimal point
thanks in advance
paullimapa
don't run this line in the code:
                   txt (rh:2chge dst 2)
instead run this line:
                  txt (rtos dst 2 2) ;; just return distance as string with decimal value and 2 digit precision
then the code won't run the function rh:2chge which adds the 0s in front of the #s or the 01+
Paul Li
IT Specialist
@The Office
Sally_Ward8TWBK
thanks so much. 🙂
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
