place a circle if the attribute value is less than 20.0
nanja_c86
nanja_c86
I have a Lisp code designed to place a circle if the value is less than 20.0, but it's not functioning properly. Could you please review and correct the Lisp code for me?
(defun c:PlaceCircle ()
(vl-load-com)
(setq blockName "DN_EOL")
(setq attributeName "HIGH_DIGITAL")
(setq circleDiameter 40.0)
(setq blk (tblsearch "block" blockName))
(if blk
(progn
(setq ss (ssget "_X" (list (cons 0 "INSERT")(cons 2 blockName))))
(if ss
(repeat (sslength ss)
(setq ent (ssname ss 0))
(setq atts (entget ent))
(setq attValue nil)
(foreach att atts
(if (eq (car att) (cons 2 attributeName))
(setq attValue (cdr att))
(if (and attValue (< (atof attValue) 20.00))
(progn
(setq insertPt (cdr (assoc 10 (entget ent))))
(command "_CIRCLE" insertPt circleDiameter)
(princ)
ВeekeeCZ
Where is the code coming from? Whoever made this should learn how to get attributes.
(vl-load-com)
(defun c:AttCheck ( / b a v r s i e x)
  (setq b "DN_EOL"
	a "HIGH_DIGITAL"
	v 20
	r 20)
  (if (setq s (ssget "_X" (list '(0 . "INSERT") (cons 2 b))))
    (repeat (setq i (sslength s))
      (and (setq e (ssname s (setq i (1- i))))
	   (not (vl-catch-all-error-p (setq x (vl-catch-all-apply 'getpropertyvalue (list e a)))))
	   (< (atof x) v)
	   (entmake (list '(0 .  "CIRCLE") (assoc 10 (entget e)) (cons 40 r))))))
  (princ)
nanja_c86
@ВeekeeCZ
I'm uncertain about the author of this Lisp code. Thank you for your assistance; it's now functioning perfectly. I appreciate your help.
CLL_PBE
You mean only for the value "HIGH DIGITAL" ? is it targeting the two other tags?  and is the target always less than 20? or does it depend on the values of the two other attributes?
nanja_c86
@CLL_PBE
its only for the value "HIGH DIGITAL" tag. It will be Always less than 20. It will not depend on other two tag values.
