Change text to mtxt, add annotative scales LISP
Kate.RobinsonR9FXS
Kate.RobinsonR9FXS
I am exporting contour xrefs from a 3d program which spits out the labels as text. I have created a lisp which converts this text to mtext, adds a background mask, and justifys all the text to middle centre and this works great. What i have also created is a simple script which turns on ANNOAUTOSCALE then cycles through the CANNOSCALE of certain scales which essentially gives me somewhat automated annotative text scales.
The manual things i have to do
1. open and select all text to make it annotative
2. run the script which gives annotation scales to my text
3. run the lisp which turns all the txt to mtxt etc
4. change the background mask to 1.1 not 1.5 as that is set as the default.
Information im looking for.
1. is it possible to set the text objects to annotative? alternatively could set the a textsyle which is already annotative?
2. is it possible to change the background mask border offset via lisp? (have googled alot but no dice)
2. is it possible to add my lisp and script together to run all at once
Lisp txttomtext code
(defun C:ContourExport (/ ss1 en n)
;; Select all Text objects
(setq ss1 (ssget "_X" (list (cons 0 "TEXT"))))
(setq i -1)
(if ss1
(repeat (sslength ss1)
(setq elist (cdr (assoc -1 (entget (ssname ss1 (setq i (1+ i)))))))
(command "TXT2MTXT" elist "")
;; Select all MText objects
(setq ss1 (ssget "_X" (list (cons 0 "MTEXT"))))
(if ss1
(progn
(setq n (sslength ss1))
(repeat n
(setq n (1- n))
(setq en (vlax-ename->vla-object (ssname ss1 n)))
(if (vlax-property-available-p en 'BackgroundFill)
(vlax-put en 'BackgroundFill 1)
(vlax-put en 'AttachmentPoint 5) ; Set the attachment point to middle center
(prompt "\nNo MText found.")
(princ)
Script code
ANNOAUTOSCALE 1
CANNOSCALE "1:500 (M)"
CANNOSCALE "1:2000 (M)"
CANNOSCALE "Metres 1:1000"
ВeekeeCZ
Post 2 dwgs, initial state and desired.
Kate.RobinsonR9FXS
done
ВeekeeCZ
Those annotative styles, can't they be part of the dwt you're exporting to?
Kate.RobinsonR9FXS
Do you mean the text styles? they are apart of the dwt but i can't export to those specific styles if that whats you mean
ArialNarrow2.5 is the anno Texstyle i would put them on after export.
ВeekeeCZ
Ok, I see, but 1:2000 scale is not part of it.
(vl-load-com)
(defun c:CountourExportsTextFix ( / s i e ts)
  (if (setq s (ssget "_X" '((0 . "TEXT"))))
    (progn
      (setvar '*txt2mtxtcombinemtext 0)
      (command "_.TXT2MTXT" s "")))
  (setq ts (tblobjname "Style" "ArialNarrow2.5"))
  (if (setq s (ssget "_X" '((0 . "MTEXT"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i))))
;      (setpropertyvalue e "Attachment" 5) it does not change the point
      (vlax-put (vlax-ename->vla-object e) 'AttachmentPoint 5)
      (setpropertyvalue e "BackgroundFill" 1)
      (setpropertyvalue e "UseBackgroundColor" 1)
      (setpropertyvalue e "BackgroundTransparency" 0)
      (setpropertyvalue e "BackgroundScaleFactor" 1.1)
      (setpropertyvalue e "Annotative" 1)
      (and ts (setpropertyvalue e "TextStyleId" ts))
  (setvar 'ANNOAUTOSCALE 1)
  (setvar 'CANNOSCALE "1:500 (M)")
  (command "_.-scalelistedit" "_d" "1:2000 (M)" "_add" "1:2000 (M)" "1:2" "_e")
  (setvar 'CANNOSCALE "1:2000 (M)")
  (setvar 'CANNOSCALE "Metres 1:1000")
  (setvar 'ANNOAUTOSCALE 0)
  (princ)
Kate.RobinsonR9FXS
That worked a treat! Thanks heaps.
The anno scales can definitely be added to the dwt, not sure why 1:2000 was missing.
