Place a block at start and end of every line on layer
I have a layer that only contains pathing for an automated vehicle. I then need to place a "QR CODE" block at every start and end point of all the lines of that pathing. The placed block needs to be on a different layer. I got ChatGPT to start the code I'm just having a hard time getting it working and am not a very competent programmer. Any suggestions or help guys?
(defun c:QRPlace ()
(setq line_layer "MUSA-AGV-AMR PATH")
(setq qr_block_name "QR CODE")
(setq qr_block_layer "MUSA-QR CODES")
(setq tolerance 0.05) ; 5% tolerance for coordinate check
(if (and (tblsearch "LAYER" line_layer) (tblsearch "BLOCK" qr_block_name) (tblsearch "LAYER" qr_block_layer))
(progn
(setq points '()) ; Initialize list to store points
(setq ss (ssget "_X" (list '(0 . "LINE") '(8 . line_layer)))) ; Select lines on specified layer
(if ss
(progn
(setq i 0)
(while (< i (sslength ss))
(setq ent (ssname ss i))
(setq startpt (cdr (assoc 10 (entget ent)))) ; Get the start point of the line
(setq endpt (cdr (assoc 11 (entget ent)))) ; Get the end point of the line
; Check for duplicates or close coordinates and add to the list
(if (and (not (member startpt points :test 'equalp))
(not (member endpt points :test 'equalp))
(not (is-close-coord startpt points tolerance))
(not (is-close-coord endpt points tolerance)))
(progn
(setq points (cons startpt points))
(setq points (cons endpt points))
(setq i (1+ i))
; Insert QR CODE block at unique points in the list
(foreach point points
(command "_insert" qr_block_name point) ; Insert block at the point
(command "_.chprop" "_last" "" "LA" qr_block_layer "") ; Change block to QR CODES layer
(princ "\nQR CODE blocks inserted successfully at unique points of lines on specified layer.")
(princ "\nNo lines found on the specified layer.")
(princ "\nLayer or block not found. Please check the names.")
(defun is-close-coord (coord lst tol)
; Check if the coordinate is close to any coordinate in the list within the given tolerance
(foreach item lst
(if (and (<= (distance coord item) tol) (>= (distance coord item) (- tol)))
(return T)
nil
