Place a block at start and end of every line on layer
jacob.dillingham.engr
I have a layer that only contains pathing for an automated vehicle. I then need to place a "QR CODE" block at every start and end point of all the lines of that pathing. The placed block needs to be on a different layer. I got ChatGPT to start the code I'm just having a hard time getting it working and am not a very competent programmer. Any suggestions or help guys?
(defun c:QRPlace ()
(setq line_layer "MUSA-AGV-AMR PATH")
(setq qr_block_name "QR CODE")
(setq qr_block_layer "MUSA-QR CODES")
(setq tolerance 0.05) ; 5% tolerance for coordinate check
(if (and (tblsearch "LAYER" line_layer) (tblsearch "BLOCK" qr_block_name) (tblsearch "LAYER" qr_block_layer))
(progn
(setq points '()) ; Initialize list to store points
(setq ss (ssget "_X" (list '(0 . "LINE") '(8 . line_layer)))) ; Select lines on specified layer
(if ss
(progn
(setq i 0)
(while (< i (sslength ss))
(setq ent (ssname ss i))
(setq startpt (cdr (assoc 10 (entget ent)))) ; Get the start point of the line
(setq endpt (cdr (assoc 11 (entget ent)))) ; Get the end point of the line
; Check for duplicates or close coordinates and add to the list
(if (and (not (member startpt points :test 'equalp))
(not (member endpt points :test 'equalp))
(not (is-close-coord startpt points tolerance))
(not (is-close-coord endpt points tolerance)))
(progn
(setq points (cons startpt points))
(setq points (cons endpt points))
(setq i (1+ i))
; Insert QR CODE block at unique points in the list
(foreach point points
(command "_insert" qr_block_name point) ; Insert block at the point
(command "_.chprop" "_last" "" "LA" qr_block_layer "") ; Change block to QR CODES layer
(princ "\nQR CODE blocks inserted successfully at unique points of lines on specified layer.")
(princ "\nNo lines found on the specified layer.")
(princ "\nLayer or block not found. Please check the names.")
(defun is-close-coord (coord lst tol)
; Check if the coordinate is close to any coordinate in the list within the given tolerance
(foreach item lst
(if (and (<= (distance coord item) tol) (>= (distance coord item) (- tol)))
(return T)
nil
Kent1Cooper
ChatGPT is notoriously bad at a lot of AutoLisp things -- it really just doesn't know enough about how it works yet.  Some things I notice right off the bat:
You can't use a variable name in that way, inside a "quoted list" where things that need evaluation are not allowed.  It would need to be:
(setq ss (ssget "_X" (list '(0 . "LINE") (cons 8 line_layer)))) ; Select lines on specified layer
Those have too many arguments for a (member) function, and the :test 'equalp parts must be coming from some other programming language or something.
(return T)
The (distance) function always returns a positive number, so the (and) there and the second (distance) function it contains are wrong.
And there's no (return) function -- probably also something ChatGPT is assuming based on some other programming language.
Kent Cooper, AIA
paullimapa
I would also change this section of the code:
You can avoid the chprop command by setting that layer current before inserting the block like this (of course this all assume you have a layer "MUSA-QR CODES"):
(setq clayer (getvar 'clayer)) ; save current layer setting
(setvar 'clayer qr_block_layer) ; set the desired layer current
; then run foreach loop
(foreach....
; after foreach loop
(setvar 'clayer clayer) ; restore layer back to original setting
You can also learn the sequence of the insert command by entering the following at the command prompt:
Command: -INSERT
Enter block name or [?] <QR CODE>: QR CODE
Units: Unitless   Conversion: 1.0000000000E+00
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate]: 0,0
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>: 1
Enter Y scale factor <use X scale factor>: 1
Specify rotation angle <0>: 0
The lisp code equivalent would then be:
(command "_.Insert" qr_block_name point 1 1 0) ; Insert block at the point
Paul Li
IT Specialist
@The Office
Sea-Haven
Just a suggestion, Google "block at every start and end point of all the lines Autocad lisp" what your asking for has been solved before.
