PL-DIET question (Kent's lisp)
zasanil
zasanil
Greetings,
I am trying to use the PLD that Kent wrote and I had a question about it. Is it supposed to change polyline with lines forming arcs into true arcs? An example of what I am trying to do is attached. Basically I'm trying to change all the corners into "true" arcs instead of line segments. I've tried various setting under the PLD script but can't seem to make it work.
Dan Nicholson C.I.D.
PCB Design Engineer
Kent1Cooper
Unfortunately, no, it won't do that.  But it's amazing what a Search will turn up -- check this out.
Kent Cooper, AIA
zasanil
Hi Kent,
I tried that but it wasn't working as expected. For some reason I though the PLD script handled those conversions as wel. Oh well. I'll keep searching for an alternative that works.
Thanks!
PCB Design Engineer
