custom fillet lisp
custom fillet lisp
E.S.7.9
custom fillet lisp
E.S.7.9
hi , guys
i would like to be a good programmer but unfortunatly my knowledge about it simply not more then make some modfication in existing lisp routine , so this time i need a fillet lisp
basicly i wanna select a line which already exist , and specify a point somwhere in space , routine will draw a perpendicular line from this point to my selected line , from this moment i need 2 options , in the first option ; i wanna specify fillet direction with mouse click ( if i may ) , in thr second  option ; routine will make 2 sides fillet base on perpendicular point ..
i attached a jpg file for  better understanding ..
it would be nice if somebody can share with me similar lisp code
thank you , again
marko_ribar
Answered here :
http://www.cadtutor.net/forum/showthread.php?45999-Continuous-Fillet-LISP/page3&p=#23
HTH, M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
ВeekeeCZ
Marko's lisp is pretty complex, so here is my simple routine (someone could say dirty). It makes a both side connection. So it's the toy you can play with and make your another type of connetion 🙂
Spoiler
(defun c:ObjCon2 ( / *error* adoc nVAR oVAR pto en ptl vrt pt0 pt1 em)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (mapcar 'setvar nVAR oVAR)
    (vla-endundomark adoc)
    (princ))
  (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
  (setq oVAR (mapcar 'getvar (setq nVAR '("TRIMMODE" "FILLETRAD" "OSMODE" "ORTHOMODE" "SNAPMODE" "BLIPMODE" "CMDECHO"))))
  (if (and (not (initget 0))
	   (setq pto (getpoint "\nPick a point on the OBJECT: "))
	   (not (initget 0))
	   (mapcar 'setvar nVAR '(0 10 128 0 0 0 1))
	   (setq ptl (getpoint pto "\nPick a point on the LINE: "))
	   (setq en (nentselp ptl))
	   (setq en (car en))
	   (wcmatch (cdr (assoc 0 (entget en))) "LINE,LWPOLYLINE")
	   (setq vrt (fix (vlax-curve-getParamAtPoint en ptl))
		 pt0 (vlax-curve-getPointAtParam en vrt)
		 pt1 (vlax-curve-getPointAtParam en (1+ vrt)))
    (progn
      (setvar 'OSMODE 0)
      (setq em (entmakex (list (cons 0 "LINE")
			       (cons 10 pto)
			       (cons 11 ptl))))
      (command "_.FILLET" "_U"
	                  (cons em (list pto)) (cons en (list pt0))
	                  (cons em (list pto)) (cons en (list pt1))
	       "_.TRIM" ""
	                "_C"
	                (polar ptl (* 1.25 pi) 0.01)
	                (polar ptl (* 0.25 pi) 0.01)
  (*error* "end")
  (princ)
E.S.7.9
Thank you both guys , that two lisp are exactly what i want
