Hello, cand you help me with the following:
I need a lisp to measure perpendicular distances (dim aligned) from Polyline1 vertices, perpendicular to Polilyne 2.
Thank you!
Solved by Kent1Cooper. Go to Solution.
@Anonymous wrote:
....I need a lisp to measure perpendicular distances (dim aligned) from Polyline1 vertices, perpendicular to Polilyne 2.
Welcome to these Discussion Boards!
In very simplest terms, something like this seems to do that with LWPolylines:
(defun C:TEST (/ pl1 pl2)
(setq
pl1 (car (entsel "\nSelect Polyline 1: "))
pl2 (car (entsel "\nSelect Polyline 2: "))
); setq
(setvar 'dimse1 1); not essential, but I think preferable
(setvar 'dimse2 1); likewise
(foreach ver (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget pl1)))
(command "_.dimaligned"
ver
(vlax-curve-getClosestPointTo pl2 ver)
); command
); foreach
); defun
No allowance for running object snap, no verification of appropriate selection, no setting of desired Layer or Dimension Style, no saving/resetting of System Variables, etc., yet, but see what you think.
Hi cristianciocoi,
Something quick and dirty.
Is this what you are looking for:
(defun c:test (/ coords poly2) (setq cords (Poly-Pts (vlax-ename->vla-object(car (entsel "\nFirst poly:")))) poly2 (vlax-ename->vla-object (car (entsel "\nSecond poly:"))) ) (foreach x cords (vl-cmdf "dimaligned" x (vlax-curve-getclosestpointto poly2 x) x) ) ) ;;; Poly-Pts (gile) ;;; Returns the vertices list of any type of polyline (WCS coordinates) ;;; ;;; Argument ;;; pl : a polyline (ename or vla-object) (defun Poly-Pts (pl / pa pt lst) (vl-load-com) (setq pa (if (vlax-curve-IsClosed pl) (vlax-curve-getEndParam pl) (+ (vlax-curve-getEndParam pl) 1) ) ) (while (setq pt (vlax-curve-getPointAtParam pl (setq pa (- pa 1)))) (setq lst (cons pt lst)) ) )
Hope it helps,
dicra
Thank you for your help! You have saved me from a lot of tedious work. Again Thank You!
Hello every one.
I tried to use this lisp code for solving my soloution, but i cant use it for exactly my porpuse.
My solution:
I need PREPENDICULAR dimalined form all of polyline1 on polyline2(not polyline2 vertice!)
Polyline2 vertices is not important for me.just polyline1 vertices on nearest prependicular point of polyline2.
Sample image and dwg files are attached.
Thannks.
Since they're both labeled POLYLINE1, I'm not positive that I understand correctly, but if you pick the outer green one first, I think the "TEST" command does what you want, except perhaps that it puts the dimension text inside the curves rather than outside as in your example. To get the text on the outside, just reverse the two dimension definition point lines in the code:
ver
); command
Thanks for your quick response.
Sorry,it was my mistake.now the polyline name corrected.
BUT The "TEST" lisp cant draw a dimention from vertices on along of green white curve(polyline).
here is the tried lisp result.
Please see it.
Thanks for your help.
I suspect you have some running Object-Snap mode(s) on. Turn them off, and try again. Turning them off can be built into the routine, so that you don't need to make sure you do that before you run it, but was one of several things I didn't spend the time to put in it originally. The simplest way in this situation is probably:
"_none" (vlax-curve-getClosestPointTo pl2 ver)
"_none" ver
); command
