part-mark is not collision with other objects.
xuantientutungXUK6E
xuantientutungXUK6E
hello everyone,
i try to find away which i can know the part-mark is not collision with the others object.
i want to make a lisp to put part-mark automated, so it can reduce my editting time.
It is very fascinating.
hak_vz
If you want to receive a solution to your request upload sample drawing with your block, it's much easier to create a code and test. Try to do this in your future requests.
If you have some knowledge of autolisp try to write some code, or at least idea how you think it should work. How it has to handle collision with other objects?
Miljenko Hatlak
Sea-Haven
The day some one perfects text collision the world will rejoice, all sorts of attempts with fuzz factors have been presented before. In the Civil world labeling points has been a cad nightmare since cad started.
stevor
Functions SSGET "f" or SSGET "c" may be what you could use
 to sense a 'collision' and move your boxed leader text.
See http://www.lee-mac.com/ssget.html for an explanation
of the SSGETs  that can be comprehended.
S
Kent1Cooper
@stevor wrote:
Functions SSGET "f" or SSGET "c" may be what you could use to sense a 'collision' and move your boxed leader text. ....
Finding  collisions is the comparatively easy part.  The real challenge is finding where to Move something to.   You can Move it "somewhere" and check again, but what if you also find some collision(s) there?  Do you go farther in the same direction?  Try a different direction?  How should a routine decide what direction and how far away to try in the first place?  Is there a limit to how far away you're willing to reposition something if there's too much other stuff to collide with nearby?  Etc., etc.  Hence @Sea-Haven's comments -- this is a huge challenge that has been raised before, but I don't recall anyone finding a reliable/foolproof solution.
Kent Cooper, AIA
ronjonp
@Kent1Cooper  Good points. I wrote some code to cleanup a large project a while back that found the collisions then zoomed to the object so it could be manually moved using GRREAD. Not a perfect solution but worked well for me. 🍻
Sea-Haven
Every one is right could do say every 20 degrees at a radius do a full circle go next radius do again but how far away is a problem = no solution.
I have seen civil point labelling auto un clashed but labels lose there simple association with the point. Which is which.
