Parabolic curve y=-x*x
Message 1 of 13
How to write a parabolic curve (equation; y=-x^2) in AutoLISP?
Plz help me.
Replies (12)
Message 2 of 13
Kent1Cooper
Try this.  Call for a "degree" of 2, -1 coefficient on X^2, and the default 0 for the coefficient on X and the constant.
Kent Cooper, AIA
Message 3 of 13
Shneuph
It would be
(expt x 2)
Edit:
-x would be
(expt (* -1 x) 2)
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Message 4 of 13
Kent1Cooper
@Shneuph wrote:
-x would be
(expt (* -1 x) 2)
You can make a number negative directly with a (-) function, rather than multiplying it by -1.  That can be just:
(expt (- x) 2)
But be careful about what you ask for.  That will give you the same result as (expt x 2) [squaring a negative number gives a positive number].  I suspect they're looking instead for this:
(- (expt x 2))
Another way:
(* x (- x))
Kent Cooper, AIA
Message 5 of 13
JamesMaeding
also note that you can make a parabola in acad natively with a 3 point heavyweight pline, with smoothing.
set splinesegs as needed to get resolution desired.
Civils have done this for a long time to get vertical curves drawn accurately.
snippet of code we use
(COND ((<= VCL 500) (SETQ SEGS 100))
            ((<= VCL 1000) (SETQ SEGS 160))
            ((<= VCL 2000) (SETQ SEGS 240))
            ((> VCL 2000) (SETQ SEGS 360))
      (SETVAR "splinetype" 5)
      (SETVAR "splinesegs" SEGS)
  ;DRAW POLYLINE
      (COMMAND "pline" BVC PVI EVC "")
      (COMMAND* "pedit" "l" "s" "")
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 6 of 13
JamesMaeding
seriously, that needs a login to download, here is the code:
;;  PolynomialFunction.lsp [command name: PF]
;;  To draw the curve defined by a Polynomial Function in the form Y = a sum of
;;    coefficients on X raised to a descending series of any number of integer powers,
;;    and a constant, e.g. Y = X^4 - 2X^3 + 4.5X^2 - 12X + 17.9
;;  Asks User for whether to draw Spline [uses default start/end tangent directions]
;;    or Polyline of line segments [which can be smoothed with PEDIT Fit], origin to
;;    draw in relation to [X-Y axis intersection], degree [highest exponent applied to
;;    powers of X], coefficient at each degree, constant, bounds in X direction, and
;;    precision [size of increment in X direction between calculated values of Y].
;;  Draws on current Layer, in current Coordinate System.  Places a Point entity at
;;    User's selected origin for reference, if no Point there on current Layer already.
;;  Remembers all choices/options/values, and offers as defaults on subsequent use,
;;    so that function can be run comparatively with [for example] coefficient on just
;;    one power of X changed without needing to re-enter base, other coefficients, etc.
;;  Starts at left bound and proceeds at precision [X increment] intervals.  Note:  If
;;    precision does not divide evenly into overall range of bounds, will stop at last
;;    increment inside bounds, short of right bound by less than one increment.
;;  [Originally included constant as "coefficient" applied to X^0, but if/when X value
;;    is 0, results in (expt 0 0) and "error: function undefined for 0 in negative power."]
;;  Kent Cooper, 10 December 2014
(defun C:PF (/ *error* ev getnum doc svnames svvals n coeffs x); = Polynomial Function
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (prompt (strcat "\nError: " errmsg))
    ); if
    (mapcar 'setvar svnames svvals); reset System Variables
    (vla-endundomark doc)
    (princ)
  ); defun - *error*
  (defun ev (opt); = EValuate what's in global *pf... variable with 'opt' ending
    (eval (read (strcat "*pf" opt)))
  ); defun - ev
  (defun getnum (opt pr f1 f2); = GET NUMerical value for global variable
    ; pr = prompt, f1 = (getreal) or (getint), f2 = (rtos) or (itoa)
    (set (read (strcat "*pf" opt)); makes *pfdeg, *pfcon, or *pfinc
      (cond
        ( (f1 ; = (getint) for *pfdeg, (getreal) for others
            (strcat "\n" pr " <"
              (cond ; default:
                ((ev opt) (f2 (ev opt))); prior value
                ((= opt "inc") "1"); on first use for *pfinc
                ("0"); on first use for others
              ); cond
            ); strcat
          ); f1
        ); User input condition
        ((ev opt)); Enter with prior value
        ((= opt "inc") 1); Enter on first use for *pfinc
        (0); Enter on first use for others
      ); cond
    ); set
  ); defun
  (defun getbound (which side / boundprev boundtemp)
    ; which = "in" or "ax" for *pfminX or *pfmaxX; side = "left" or "right"
    (setq boundprev (if (ev (strcat "m" which "X")) (rtos (ev (strcat "m" which "X"))) "0"))
      ; default as text [0 if no prior use]
    (while
      (not
        (and
          (not (initget 128)); allow typing value; (not) wrapper to return T
          (setq boundtemp
            (cond
              ( (getpoint
                  (strcat
                    "\nM" which "imum X relative to origin, or pick point for " side " bound <"
                    boundprev
                  ); strcat
                ); getpoint
              ); picked point or typed value
              (boundprev); Enter
            ); cond & boundtemp
          ); setq
          (or (listp boundtemp) (distof boundtemp)); point or valid numerical typed entry
          (if (= which "ax")
            (> ; then -- right bound is to right of left bound
              (if (listp boundtemp); picked a point
                (car (mapcar '- boundtemp *pfbase)); then -- X relative to origin
                (distof boundtemp); else -- typed value
              ); if
              *pfminX
            T ; else [*pfminX]
          ); if
        ); and
      ); not
      (prompt
        (strcat
          "\nRequires numerical typed entry or point"
          (if (= which "ax") " higher than/to right of left bound" "")
        ); strcat
      ); prompt
    ); while
    (set (read (strcat "*pfm" which "X")); makes *pfminX or *pfmaxX
      ); if
    ); set
  ); defun -- getbound
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (vla-startundomark doc)
  (setq ; System Variable saving
    svnames '(osmode cmdecho blipmode plinewid)
    svvals (mapcar 'getvar svnames)
  ); setq
  (initget "Spline Pline")
  (setq
    *pfetyp ; global: Polynomial Function Entity TYPe
    (cond
      ( (getkword
          (strcat
            "\nEntity type to draw [Spline/Pline] <"
            (if *pfetyp (substr *pfetyp 1 1) "S"); default [initial letter]: Spline on first use
          ); strcat
        ); getkword
      ); User entry condition
      (*pfetyp); Enter with prior value
      ("Spline"); Enter on first use
    ); cond & *pfetyp
    *pfbase ; global: Polynomial Function BASE point
    (cond
      ( (getpoint
          (strcat
            "\nOrigin base point [X-Y axis intersection for function] <"
            (if *pfbase ; default [in current Units format]: 0,0 on first use
              (strcat (rtos (car *pfbase)) "," (rtos (cadr *pfbase))); then
              (strcat (rtos 0) "," (rtos 0)); else
            ); if
          ); strcat
        ); getpoint
      (*pfbase); Enter with prior value
      ('(0 0)); Enter on first use
    ); cond & *pfbase
  ); setq
  (if (not (ssget *pfbase (list '(0 . "POINT") (cons 8 (getvar 'clayer)))))
    ; not one there already [only one Point for multiple runs with same base]
    (entmake (list '(0 . "POINT") (cons 10 *pfbase)))
  ); if
  (initget 4); no negative
  (getnum "deg" "Degree [highest exponent on X]" getint itoa)
  (repeat (setq n *pfdeg)
    (setq
      coeffs ; list of powers of X paired with coefficients to multiply them by
        ; [local variable: re-build each time, because of possibility of different degree]
      (cons ; add to list
        (cons ; individual exponent paired with its coefficient
          n ; the exponent on X
          (cond
            ( (getreal
                (strcat
                  "\nCoefficient on X"
                  (if (> n 1) (strcat "^" (itoa n)) "")
                  (cond ; default:
                    ((assoc n *pfcoeffs) (rtos (cdr (assoc n *pfcoeffs)) 2 4)); prior value if present
                    ("0"); on first use
                  ); cond
                ); strcat
              ); getreal
            ((cdr (assoc n *pfcoeffs)))
            (0)
          ); cond
        ); cons
        coeffs
      ); cons & coeffs
    ); setq
    (setq n (1- n))
  ); repeat
  (getnum "con" "Constant" getreal rtos); makes global *pfcon
  (getbound "in" "left")
  (getbound "ax" "right")
  (setq
    *pfcoeffs coeffs ; global: save to offer defaults on subsequent use
    n -1 ; replacing earlier use of variable 'n'
  ); setq
  (initget 6); no 0, no negative
  (getnum "inc" "Precision [increment between X values]" getreal rtos); makes global *pfinc
  (mapcar 'setvar svnames '(0 0 0)); turn off object snap, command echoing, blips
  (if (= *pfetyp "Pline") (setvar 'plinewid 0))
    ; ^-- delete/comment out above line to use whatever current Polyline width is,
    ; or specify standardized width, or prompt User for width
  (command (strcat "_." *pfetyp)); "_.Pline" or "_.Spline"
  (repeat (1+ (fix (/ (- *pfmaxX *pfminX) *pfinc)))
    (command ; feed calculated points out to drawing command
      (list ; build point XY coordinates
        (+ (car *pfbase) (setq x (+ *pfminX (* *pfinc (setq n (1+ n)))))); X coordinate
        (+ ; Y coordinate
          (cadr *pfbase)
          (apply '+ ; add up powers of X multiplied by their coefficients
            (mapcar '(lambda (term) (* (cdr term) (expt x (car term)))) coeffs)
          ); apply
          *pfcon ; constant
        ); + [Y coordinate]
      ); list
    ); command
  ); repeat
  (command ""); finishes command if Polyline, ends point designations if Spline
  (if (= *pfetyp "Spline") (command "" "")); default end tangents finish command
  (princ)
); defun
(vl-load-com)
(prompt "\nType PF to draw a Polynomial Function.")
Message 7 of 13
john.uhden
Ahem.  All you need to do is to create a 3-point polyline, then PEDIT Spline curve, then in properties, change its Fit/Curve to quadratic.
I'm sure it can be done programatically, but I will leave that up to you wizards.  Just do an entget or a dump.
BTW, it will remain a 3-point polyline, just a little heavier.  C'mon, James, you've seen them in Land Desktop a million times; that's how they drew vertical curves, parabolas you know?  I still can't figure out the guy from Egypt or wherever who claimed his vertical curves were arcs.  Maybe they were visited by a different strain of alien ancestors.  The closest thing we have to a pyramid is a salt dome (which you guys down south may not have).  Anyway, they are using magnesium chloride more these days, as a liquid.
John F. Uhden
Message 8 of 13
JamesMaeding
@john.uhden
Yep, that is what my code does 2 posts back.
The big old lisp thing one post back was someone elses code that I never have used.
Message 9 of 13
john.uhden
Oh yeah.  Put the blame on someone else, eh?
Yes, you do deserve credit for a few posts back.  I'll attend to that.  You're a good guy, James.  I usually tease only those whom I like.
John F. Uhden
Message 10 of 13
JamesMaeding
@john.uhden
for sure, just wanted you to know I did not throw up that huge set of code when a couple lines would do it.
So few civils know a polyline with quadratic smooth is exactly the same shape as a vertical curve!
Message 11 of 13
Kent1Cooper
No, it doesn't.  You never need to log in to download files on the CAD Tips site.  You do if you want to comment on one, and some other tid-bits, but anyone can download Tips -- see the first sentence under Register on the main CAD Tips page -- if not logged in, you are the "guest" they refer to.
Kent Cooper, AIA
Message 12 of 13
wkmvrij
Very interesting reading as well : http://www.digitalcad.com/2001/05_may/features/math1.htm. There is a link in it to a LSP file that will plot curves too.
Message 13 of 13
JamesMaeding
I see now, chrome was somehow hiding the download, even when I picked.
So I switched to IE which is how I normally log into cadalyst and it dis but then chrome finally showed the download, odd.
Anyway, I like Cadalys for Robert Green's articles. Poor Lynn Allen's videos have become hokey. I still think she does top notch training composition, just wish it was a little more serious like she was years ago.
