Pan all Viewports in selected Layouts
jtm2020hyo
Message 1 of 14
jtm2020hyo
I need to select multiple layouts and enter a code to PAN  all viewports in the typed coordinates
example:
*Layout1:
  2 viewports, the first viewing
*Layout2:
  3 viewports, one
*Layout1 (1): (this is a copy)
  2 viewports,
*Layout2 (1): (this is a copy)
  3 viewports, one
So I need to pan all viewports from Layout1 (1) and Layout2 (1) 1000 units to axis Y (x:0,y:1000,z=0)
So I want to request to create an LSP, VBA, FAS or any routine to pan all viewports from selected layouts to any typed coordinates.
I found nothing like this in google.
Replies (13)
Message 2 of 14
Sea-Haven
1st don’t you mean move the viewports.
ok if you get extmin extmax this is the corner points of the viewports. So just use these with move and window option using the 2corners then the new point co-ords
Message 3 of 14
jtm2020hyo
thanks for your help.
I will try to explain better what I need because of my bad English
example, I need to move viewports like this:
____________________________________
*Layout1:
  2 viewports, target view (red 1) and (red 2)
*Layout2:
  3 viewports,  target view (red 3) (red 4) and (red 5)
*"Layout1 (1)": (this is a copy of Layout1)
  2 viewports, target view (red 1) and (red 2))
*"Layout2 (1)": (this is a copy of Layout2)
______________________________________
I need to pan all viewports ,from "Layout1 (2)" and "Layout2 (2)" , 6558.8231 units to axis Y (x:0,y:6558.8231,z=0)
like this:
*Layout1:
*Layout2:
*"Layout1 (2)": (this is a copy of Layout1)
  2 viewports, target view (white 1) and (white 2)
*"Layout2 (2)": (this is a copy of Layout2)
  3 viewports, target view (white 3) (white 4) and (white 5)
here images to a better explaining (square red and white are viewport projections):
So I need a routine (VBA or LSP or FAS or anything) to "-PAN" ( X:0, Y:6558.8231, Z:0, in the example) all viewports in selected LAYOUTS ("Layout1 (2)" and "Layout2 (2)" in the example)
Message 4 of 14
marko_ribar
Go to Paper Space... Step into desired viewport by double clicking inside... Grab variable (setq ce (getvar 'viewctr))... Calculate new ce variable as (setq ce (mapcar '+ ce '(0.0 6558.8231 0.0)))... Grab variable (setq vs (getvar 'viewsize))...
Finally, instead of PAN command, use (vl-cmdf "_.zoom" "_c" "_non" ce vs)... Repeat process for all viewports and in all desired Layouts... Automate procedure into *.lsp file, so that you can do it automatically, just by selecting desired viewport... I hope it is clear... Now go to CAD and finish your job as required...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 5 of 14
jtm2020hyo
I need to do this to 500 layouts.
it is possible to do this without joining Layouts?
I just need selected LAYOUT tabs with Ctrl-key and clicking and do that process with a command line.
Message 6 of 14
marko_ribar
Here is for single viewport :
(defun c:processviewport ( / *error* *adoc* s vp ce vs cenew )
  (vl-load-com)
  (defun *error* ( m )
    (vla-endundomark *adoc*)
    (if m
      (prompt m)
    (princ)
  (setq *adoc* (vla-get-activedocument (vlax-get-acad-object)))
  (if (= 8 (logand 8 (getvar 'undoctl)))
  (vla-startundomark *adoc*)
  (while
    (or
      (prompt "\nPick VIEWPORT entity to activate...")
      (not (setq s (ssget "_+.:E:S:L" '((0 . "VIEWPORT") (-4 . "<not") (410 . "Model") (-4 . "not>")))))
    (prompt "\nMissed or picked wrong entity type...")
  (setq vp (ssname s 0))
  (vla-display (vlax-ename->vla-object vp) :vlax-true)
  (vla-put-mspace *adoc* :vlax-true)
  (vla-put-activepviewport *adoc* (vlax-ename->vla-object vp))
  (setq cenew (mapcar '+ ce '(0.0 6558.8231 0.0)))
  (vl-cmdf "_.zoom" "_c" "_non" cenew vs)
  (vla-put-mspace *adoc* :vlax-false)
  (*error* nil)
And here is for all viewports in all layouts...
(defun c:processviewportsinalllayouts ( / *error* *adoc* ct ss i vp ce vs cenew )
  (vl-load-com)
    (if ct
      (setvar 'ctab ct)
    (if m
      (prompt m)
    (princ)
  (setq ct (getvar 'ctab))
  (foreach lay (layoutlist)
    (setvar 'ctab lay)
    (setq ss (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 lay))))
    (repeat (setq i (sslength ss))
      (setq vp (ssname ss (setq i (1- i))))
      (vl-catch-all-apply 'vla-put-activepviewport (list *adoc* (vlax-ename->vla-object vp)))
  (*error* nil)
HTH., M.R.
Cheers...
Message 7 of 14
jtm2020hyo
  (vl-load-com)
    (if m
      (prompt m)
    (princ)
  (while
    (or
  (*error* nil)
  (vl-load-com)
    (if ct
      (setvar 'ctab ct)
    (if m
      (prompt m)
    (princ)
    (setvar 'ctab lay)
  (*error* nil)
HTH., M.R.
Cheers...
I was testing your routines...
...Work as you said. pretty cool, I'm new in coding and in AutoCAD, I was thinking this is not possible because I did not found something like this in 1000 pages.
I just have two requests more:
1) Can you add an option your lisp-routines to work only in selected layout-tabs?
...like this:
2) Can you add a variable to input a different coordinate value each time I need to?
Message 8 of 14
marko_ribar
I think this will be good... BTW. You have to have A2012+...
(defun c:processviewportsinallsellayouts ( / *error* selectedlayoutlist *adoc* ct ss i vp ce vs cenew ch v p1 p2 loop )
  (vl-load-com)
    (if ct
      (setvar 'ctab ct)
    (if m
      (prompt m)
    (princ)
  (defun selectedlayoutlist ( / e lst )
    (vl-load-com)
    (vlax-for lay (vla-get-layouts (if *adoc* *adoc* (vla-get-activedocument (vlax-get-acad-object))))
      (setq e (vlax-vla-object->ename lay))
      (if (= (getpropertyvalue e "TabSelected") 1)
        (setq lst (cons (getpropertyvalue e "LayoutName") lst))
    (reverse lst)
  (initget "Pick Specify")
  (setq ch (getkword "\nChoose option of translation vector input [Pick/Specify] <Specify coordinates> : "))
  (if (null ch)
    (setq ch "Specify")
  (setq loop t)
  (if (= ch "Specify")
    (while loop
      (initget 1)
      (setq v (getpoint "\nSpecify coordinates of vector translation : "))
      (if (null (acet-sys-lmouse-down)) (setq loop nil))
    (progn
      (initget 1)
      (setq p1 (getpoint "\nPick or specify start point of translation vector : "))
      (initget 1)
      (setq p2 (getpoint p1 "\nPick or specify end point of translation vector : "))
      (setq v (mapcar '- p2 p1))
  (if (vl-remove "Model" (selectedlayoutlist))
    (foreach lay (vl-remove "Model" (selectedlayoutlist))
      (setvar 'ctab lay)
        (setq cenew (mapcar '+ ce v))
  (*error* nil)
Message 9 of 14
jtm2020hyo
  (vl-load-com)
    (if ct
      (setvar 'ctab ct)
    (if m
      (prompt m)
    (princ)
    (vl-load-com)
    (reverse lst)
  (if (null ch)
    (setq ch "Specify")
  (setq loop t)
    (while loop
      (initget 1)
    (progn
      (initget 1)
      (initget 1)
      (setvar 'ctab lay)
  (*error* nil)
Your code works perfectly, just I need a minor fix.
when I move to any direction, your lisp move the viewport target distance X2
example:
when I want to move layout "12(2)" viewport to see "drawing 21", 100 units to the right, I need input 50 units
I need to input 100 units to move 100 units.
Anyway, I will keep testing your code a bit more before mark as solution.
PD: It is possible to pan viewport without join layouts individually?
Message 10 of 14
marko_ribar
Yes, you are right... That thing is because selection set of viewports is grabbed with main layout viewport which shouldn't be in selection set... So routine processed all viewports and finally as last one it processed layout viewport making pan once again for all viewports for the same distance... Here is revision of the code :
  (vl-load-com)
    (if ct
      (setvar 'ctab ct)
    (if m
      (prompt m)
    (princ)
    (vl-load-com)
    (reverse lst)
  (if (null ch)
    (setq ch "Specify")
  (setq loop t)
    (while loop
      (initget 1)
    (progn
      (initget 1)
      (initget 1)
      (setvar 'ctab lay)
      (setq ss (ssget "_X" (list '(0 . "VIEWPORT") '(-4 . "<not") '(69 . 1) '(-4 . "not>") (cons 410 lay))))
  (*error* nil)
This issue will occur and in my code for processing all layouts, so be sure to copy line (setq ss (ssget "_X" (list '(0 . "VIEWPORT") '(-4 . "<not") '(69 . 1) '(-4 . "not>") (cons 410 lay)))) and in that code... Not quite sure, but in DXF reference it is stated that code 69 is viewport ID, so I think ID=1 is main layout viewport which should be filtered out...
For your question : single viewport pan - yes you have code which should work fine, just copy+paste what I wrote in this code for user inputs for vector of translation...
Regards, M.R.
Message 11 of 14
alx86
Thanks  I was also searching for something like this! But is there a way to change the pan from Y axis to X? I need the same, but I need to move my viewports horizontally instead of vertically.
Thanks a lot
Message 12 of 14
jtm2020hyo
this lisp works for x and y
Message 13 of 14
ruqaiyakothariMWJH9
Observer
Observer
Worked a charm. Thannk you soooo much!!
Message 14 of 14
3dwannab
Thanks mark,
I modified it to do a selection of viewports to unlock and lock any that were afterwards and to enter the offset of the pan in both the X and Y direction.
;; Pans a selection of viewports in the X and Y direction.
;; This is a modification of the program here by marko_ribar: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/pan-all-viewports-in-selected-layouts/m-p/8577783#M380669
;; 3dwannab modifications on 2022.08.04 are:
;; You can select locked viewports and this will temporarily unlock them, do its business and then locks them again.
;; Message error if in modelspace.
;; Allows the user to enter X and Y offsets.
(defun c:VP_Pan_Selected (/ *error* *adoc* ce cenew ct i lock offX offY pt ss vp vs)
  (vl-load-com)
  (if (= (getvar 'tilemode) 1)
    (progn
      (acet-ui-message "You must be in paperspace for this to work!" "Computer says no.." 48)
      (exit)
  (defun *error* (m)
    (if ct
      (setvar 'ctab ct)
    (if m
      (prompt m)
    (princ)
  (if
    (and
      (setq ss (ssget (list '(0 . "VIEWPORT"))))
      (setq pt (getpoint "\nEnter X, Y Offset (Moves objects in this direction):\n"))
      (setq lock (vla-get-displaylocked (vlax-ename->vla-object vp)))
      (vla-put-displaylocked (vlax-ename->vla-object vp) :vlax-false)
      (setq offX (- 0.0 (car pt))) ;; Opposite the X value so it's easier to visualise the movement of the objects in the viewport.
      (setq offY (- 0.0 (nth 1 pt))) ;; Opposite the Y value so it's easier to visualise the movement of the objects in the viewport.
      (setq cenew (mapcar '+ ce (list offX offY 0.0)))
      (vla-put-displaylocked (vlax-ename->vla-object vp) lock)
  (*error* nil)
;; (c:VP_Pan_Selected) ;; Unblock for quick testing
