How do I make AutoCAD ignore "\" as a user input in a button macro?!
Message 1 of 13
Hi all,
I am trying to create a custom button to change the dimpost command to "\P
But every time it stops at \, thinking it's supposed to be a user input.
How can I put "\P as text that I want inputted, instead of it doing " and then stopping for user input?  I don't want to type in "\P in the middle of the command every time.
dimpost;"\P;
I thought maybe parenthesis or brackets would work, but so far it hasn't.
Thanks for any help!!
Joe
Replies (12)
Message 2 of 13
CodeDing
@Anonymous ,
I'm still a bit unclear as to what exactly you're trying to accomplish.
Are you missing your end quote? --> "\P" <--
dimpost;"\P";  ...or...  dimpost;"\\P"
Or are you trying to put the literal string --> "\P <--
dimpost;"\"\P";  ...or...  dimpost;"\"\\P";
One of these 4 hopefully works for you!
Best,
~DD
Message 3 of 13
cadffm
You can not use backslashs in menumacro, just as placeholde for one user-input.
Fullversion user? then use LISP in commandline:
(setvar "DIMPOST" "\\P")
Sebastian
Message 4 of 13
Kent1Cooper
This works for me:
(setvar 'dimpost (strcat (chr 92) "P"))
[Some, but not all, AutoLisp functions can be used in menu macros.  The (chr) function lets you avoid the actual \ character itself.]
Kent Cooper, AIA
Message 5 of 13
Kent1Cooper
@cadffm wrote:
.... use LISP in commandline:
[That doesn't do it.  It leaves you with:
(setvar "DIMPOST" "
at the command line, awaiting further input.]
Kent Cooper, AIA
Message 6 of 13
DannyNL
Since you also want the " the code below should be the one. You should be able to use this as your button macro as well.
(setvar "DIMPOST" "\"\\\\P")
Message 7 of 13
ВeekeeCZ
(setvar 'dimpost (strcat (chr 34) (chr 92) "P"))
... if " should be included.
Message 8 of 13
Kent1Cooper
[That doesn't work either -- same result as in Message 5.  Testing before posting is always a good idea....]
Kent Cooper, AIA
Message 9 of 13
DannyNL
@Kent1Cooper I did test genius, as I always do before posting. And this code works fine on my side in AutoCAD 2017.
Message 10 of 13
DannyNL
Message 11 of 13
Kent1Cooper
@DannyNL wrote:
.... And this code works fine on my side in AutoCAD 2017.
It doesn't for me in 2019.  I took the wording "the code below should  be the one" as an indication that it hadn't been tested.  And I see from your screencast now that you appear to have done all your testing at the command line.  Did you test it in a menu macro button?   That's what they want to do, but that's where it runs into trouble -- it's not the same as doing it at the command line.
Kent Cooper, AIA
Message 12 of 13
DannyNL
I stand corrected.....I did test only on the command line. Used in a function should also be fine, but in a macro it shows the same issues.
@ВeekeeCZ 's code is the working one to be used in a macro.
Message 13 of 13
This one worked for me!  Thank you!!
