PAGE SETUP FOR PUBLISH
SAFizzy
Message 1 of 8
SAFizzy
Hi Everyone,
can somebody help me in page setup.
for example i have around 50 sheets (1 file with 20 layouts/all separate sheets) with same size of page setup/plot setup. i want to apply this setting to all of the sheets to avoid repetition of work.
Replies (7)
Message 2 of 8
cadffm
In "real" not possible, but for publishing no problem.
Add youe sheets to your publish list, mark all, right mouse click in "pagesetup" column and override the
pagesetup for this publish-job.
You can select a pagesetup from one of all reachable files!
For these kind standard setup you should save the setup with a name (named pagesetup):
Go into the file, the layout, command plot and press [add...]
By this way you save the current setup with a name and you can import this pagesetup by PSETUPIN or
for your current case: Using the named pagesetup for publish-jobs.
Sebastian
Message 3 of 8
maratovich
This can be done not standard features.
We'll have to first print to PDF, and then save the file.
But you need an example of your file with the title block, for verification.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 4 of 8
SAFizzy
thanks for reply,
i know that first to print in pdf and then print from there. but i need normal page setup for publish on plotter.
Message 5 of 8
cadffm
If you have unanswered questions, ask!
But please describe in detail because you got an answer.
At which step you are struggling?
__
@cadffm
Add your sheets to your publish list,
mark all,
override the
and you can import this pagesetup by PSETUPIN or for your current case: Using the named pagesetup for publish-jobs.
Sebastian
Message 6 of 8
maratovich
Read carefully.
I did not say that you need to print from PDF.
There are methods, but I need an example of your file with a title block.
www.kdmsoft.net
Message 7 of 8
SAFizzy
Below are some screen shots where i have some page setup for pdf.
some dwgs with different size of plot
some dwgs with different plotter
i just want to use one page setup for all. either as per 1st 2nd or 3rd image.
MULTIPLE DWGS HAVE DIFFERENT PAGE SETUP.jpgPAGE SETUP CORRECTED (REQUIRED).jpgSOME DWGS HAVE DIFFERENT PAGE SETUP .jpg
Message 8 of 8
maratovich
Without an example - it is very difficult to understand you.
This will automatically set the necessary settings before printing.
You do not need to change the settings every time.
See this:
https://www.kdmsoft.net/revers.html
www.kdmsoft.net
