Lisp Required for DXF file broken text
SAFizzy
Message 1 of 8
SAFizzy
Hi Friends,
Is there a way to convert Broken text into real Text, imported from Dxf file?
Replies (7)
Message 2 of 8
cadffm
Why Lisp?? Never heard. Yo
Try command PDFSHXTEXT before you are searching for 3.part solutions.
Sebastian
Message 3 of 8
SAFizzy
dear i did't get your answer?
how to apply this command and where to write this command? PDFSHXTEXT
Message 4 of 8
cadffm
You never said which product you are using, which productversion. (your fail by starting a thread! you should ever post your product/version too)
so i have to think you are using a new version up to the newest.
PDFSHXTEXT starts with ~ 2017 version.
Okay, The 1st April is gone, so i will answer with full respect:
Where you have to write the command?
Where you have to write every input to autocad, just type in PDFSHXTEXT and press [ENTER]
How to apply this command?
Ask your help [F1] and try it yourself (Start the command and follow them)
Curious questions for someone who ask in a programmer forum for text rebuild solutions,
perhaps i misunderstood your postings, if so: Sorry.
Sebastian
Message 5 of 8
dgorsman
Define "broken text"?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 6 of 8
SAFizzy
I Received DXF file from Design software to input data, but instead of text, it is in broken lines,  i just want to convert these broken lines into real text.
Message 7 of 8
SAFizzy
i attached sample file of broken text
can some one help in this matter please?
Message 8 of 8
cadffm
Read my answer above the first time, or read it again.. Click!
After a short check: This is a really hard source to re-create Text objects.
PDFSHXTEXT isn't good enough in this case.
Possible to change the font and other text properties inside the source program?
Sebastian
