Visual LISP, AutoLISP and General Customization
Override error handler or catch error twice?
1 REPLY 1
446 Views, 1 Reply
I'm trying to set variables before and after running a script I downloaded that is encrypted. The script has it's own error handling and puts up an error message every time you end the command. My error handler is never being called, let alone the rest of the script.
Is there a way to override the error handler of an already defined function? or to catch errors that have already been caught?
(load "LBL2.LSP") ; contains "C:LBL" command
(defun c:PropertyLineLabel (/ *error* main doc)
	(vl-load-com)
	(defun main ()
		(vla-StartUndoMark (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))))
		(setvar "DIMLFAC" (/ 1 12.0))
		(setvar "LUPREC" 2)
		(C:LBL)
		(setvar "DIMLFAC" 1)
		(setvar "LUPREC" 4)
		(vla-EndUndoMark doc)
		(princ)
	(defun *error*(s)
		(princ s)
		(setvar "LUPREC" 4)
		(princ)
	(main)
Labels (1)
1 REPLY 1
CodeDing
@Anonymous ,
I believe you will need to use a global error handler. The error handler defined inside of (c:LBL) was created to HANDLE errors within that function. so if a user is "exiting" (creating an errror) inside THAT function, then THAT error handler will be called.
To alleviate this, you will need to update the internal handler for (c:LBL) OR create a global error handler.
Best,
~DD
Need AutoLisp help? Try my custom GPT 'AutoLISP Ace':
https://chat.openai.com/g/g-Zt0xFNpOH-autolisp-ace
AutoCAD Inside the Factory
