Visual LISP, AutoLISP and General Customization
OVERKILL not working...
10 REPLIES 10
Message 1 of 11
kameron1967
10045 Views, 10 Replies
Hi guys,
I am testing Overkill on Autocad 2010. I gave it fuzz distance of 0 and sometimes 0.1. Either way, it tells me it's deleted X number of entities, but when I check the count, it hasn't deleted anything.
Anyone has a routine to work around this?  I'm looking for ones that remove duplicate lines/arcs when they are on the same layer.  Thanks in advance. 🙂
10 REPLIES 10
Message 2 of 11
3wood
in reply to: kameron1967
If you can upload a drawing to show the problem that will be great.
Sometimes it is the drawing itself instead of routine has some issues to deal with.
Message 3 of 11
marko_ribar
Have a look into this topic... Maybe you'll find answer in those posts, else I agree with 3wood and upload your DWG...
http://www.cadtutor.net/forum/showthread.php?83657-I-need-overkill-and-ncopy-!please-help-me!
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 4 of 11
kameron1967
in reply to: 3wood
Here is the file.  Please test it and let me know if it's working for you and what autocad version you are using.
Message 5 of 11
hmsilva
AutoCAD 2012 SP2
Command:  OVERKILL
Select objects: Specify opposite corner: 1183 found
Select objects:
492 duplicate(s) deleted
Command: SELECT
Select objects: Specify opposite corner: 691 found
Select objects:
Command:
AutoCAD 2014 SP1
Command: OVERKILL
Select objects:
Command:
OVERKILL
Select objects:
0 duplicate(s) deleted
Command:
Tolerance: 0.1 for both...
Henrique
Message 6 of 11
gpcattaneo
in reply to: hmsilva
Henrique, in AutoCAD2010 OVERKILL is an Express Tools command.
Message 7 of 11
hmsilva
in reply to: gpcattaneo
True!
I don'd have AC2010 at the moment, if anyone else step in, later on I'll try it with AC2010...
Henrique
Message 8 of 11
kameron1967
Hi Henrique. Yes, I thought 2014 version might have a working OVERKILL command. Thanks for posting the results for me to see. 🙂
Message 9 of 11
kameron1967
in reply to: marko_ribar
Thanks for the links, Marko_ribar. They were helpful.
Message 10 of 11
hmsilva
You're welcome, Kameron
Glad you got a solution.
Henrique
Message 11 of 11
If you have attached any image in the drawing overkill will not work. Try creating a new file and crtl-copy the elements you are interested to, and PASTEORIG these entities. Execute the OVERKILL command in the new file (it will work) and copy back with PASTEORIG in the old file.  You may lose some dimension alineations.
AutoCAD Inside the Factory
