Overkill command output pop up LSP
inulobo
inulobo
Hello, I am trying to figure out a way to get the Overkill command output to show up in a pop up window.
I would like to see the items below:
0 duplicate(s) deleted
0 overlapping object(s) or segment(s) deleted
I know it can possibly be done with LSP but I am not familiar enough to write it out.
cadffm
You need to copy the content of textscreen and remove the lines except the last ~3 lines,
a simple ALERT or a small DCL can show the Information.
Interesting task, for me my textscreen will show all thing i need, incl. the overkill feedback
Or open then TextScreen
(command "CMDECHO" "1"  "_.OVERKILL" "_all" "" "_.TEXTSCR")
(command "CMDECHO" "1" "_.-OVERKILL" "_all" "" "" "_.TEXTSCR")
Sebastian
inulobo
Not sure how to create it myself but is it something like this?
(defun c:-overkill ()
(alert)
(prompt)
(princ)
cadffm
(alert "Text")
this isn't a problem, to catch the information you want is your problem.
For a beginner i would say: Let it be. Use the simple way with "TEXTSCR".
The way is. Use command LOGFILE and lispfunction OPEN and READ-LINE
 or
Copy History from Textscreen, pull out the data from windows Clipboard
Sebastian
cadffm
(defun c:-overkill () ; Why do you ewant to oberwrite an existing native command? Use another name for your routine.
(command "CMDECHO" "1"  "_.OVERKILL" "_all" "" "_.TEXTSCR")    ; Why both
(command "CMDECHO" "1" "_.-OVERKILL" "_all" "" "" "_.TEXTSCR") ; Lines?
(alert) ; alert what? (alert "HelloWorld")
(prompt)
(princ)
I am not sure, but it seams you didn't test it?
If so:
Copy the first line directly to the commandline for a test [CTRL+9]
Copy the second line directly to the commandline for a test [CTRL+9]
Sebastian
