Osnap lisp doesn't work
Hello sir.
I want to use lisp when I want to turn on Osnap.
I've used this lisp in 2006 version, but it doen't work in 2022.
Please check this lisp.
(defun c:vv()
(command "ucs" "w" "osnap""end,ins,cen,nod,int")
Thank you. Best regard.
ВeekeeCZ
No issues here.
Elaborate more - copy the command-line listing or use screencast HERE to capture the video.
john.uhden
(setvar "osmode" 16493)
John F. Uhden
Kent1Cooper
That will set those modes, but running Osnap will be turned off.  If you want it on, use 109.
But see the >other thread< with the same question [from a different User, maybe at the same company or something, since the code is identical].
Kent Cooper, AIA
