Ordinate dim alignment program work inconsistently with added text
I wrote a program to align ordinate dimensions using SUBST and ENTMOD and it works most of the time. When there is no added text in the Text Override property (such as a quantity, etc.), the program works 100% of the time; but sometimes when there is a value in the Text Override property, the dimensions will not align. It happens inconsistently and will sometimes work with added text, probably about 70% works:30% doesn't work. When it doesn't work, it doesn't move it at all. Anyone have any idea what would cause that?
devitg
Please upload the  DWG where you apply the lisp
joselggalan
I could not locate the error in your code.
Try this restructuring:
1. locate the type of ordinate dimension base (abscissa or ordinate)
2. The following selection filter by type (abscissa or ordinate)
DXF examine the manual for dimensions. code 70.
the other code is easy, try it please ..
(defun C:OrdinateDimAlign (/ OSPRE eDimBase ENTS Filter XorY XorY-Txt
			     ;|Functions|; GetX GetY jlgg-SSToList GetDimOrdinateType AlignTextDims
        ;;-------------------------- jlgg-SSToList -------------------------------
	;; selection set to list of entities
	(defun jlgg-SSToList (ss / ssl n)
	 (if (and ss (= (type ss) 'PICKSET))
	  (repeat (setq n (sslength ss))
	   (setq ssl (cons (ssname ss (setq n (1- n))) ssl))))
	);c.defun
  	;;;_______________________________________________________________________________________________________
	;; Returns "HOR" value of a point from an entities data record
	(defun GetX (eDimBase ANUM) (cadr (assoc ANUM (entget eDimBase))))
	;; Returns "VER" value of a point from an entities data record
	(defun GetY (eDimBase ANUM) (caddr (assoc ANUM (entget eDimBase))))
	;;; Determines if dims are horizontal or vertical
	(defun GetDimOrdinateType (eDimBase / Code70)
	 (setq Code70 (cdr (assoc 70 (entget eDimBase))))
	 (if (= 64 (logand 64 Code70))
	  (setq XorY 64 XorY-Txt "Abscissa")
	  (setq XorY 0  XorY-Txt "Ordinate")
	;;; Aligns dims
        (defun AlignTextDims (LstCotas / )
	 (mapcar
	   (function
	     (lambda (eDim / NewPt EntLst)
	      (setq NewPt
		     (cond
		       ((= XorY 0 ) (list 14 (GetX eDimBase  14) (GetY eDim 14) 0.0))
		       ((= XorY 64) (list 14 (GetX eDim 14) (GetY eDimBase  14) 0.0))
	      ;(princ "\nPT = ")(princ NewPt)
	      (setq EntLst (entget eDim))	; Sets EntLst to data record of ENTA
	      ;(princ "\nENTLST = ")(princ EntLst)
	      (setq EntLst (subst NewPt (assoc 14 (entget eDim)) EntLst)) ; Substitutes new point for DXF# 14
	      (entmod EntLst) ; Submits list to modify entity name contained in the list
	   LstCotas
	);defun
  ;;-------------------------- MAIN --------------------------
  (command "CMDECHO" 0)
  (setq OSPRE (getvar "OSMODE"))
  (setq Filter (list '(0 . "DIMENSION")))
  ;;Imputs user:
  (while (not eDimBase)
   (prompt "\nSelect base Ordinate dimension to align to: ")
   (cond
    ((and (setq eDimBase (ssget "_:S:E" Filter))
	  (setq eDimBase (ssname eDimBase 0))
	  (= 6 (logand 6  (cdr (assoc 70 (entget eDimBase))))) ;; = OrdinateDimension
	  ;;(vl-some (function (lambda (x) (= (cdr x) "AcDbOrdinateDimension"))) (entget eDimBase)))
    (T
     (prompt "\nNot selected Ordinate dimension..")
     (setq eDimBase nil)
  ;;; Determines if dims are horizontal or vertical:
  (GetDimOrdinateType eDimBase)
  ;; Selects dimensions to align to base
  (while (not ENTS)
   (prompt (strcat "\nSelect dimensions (" XorY-Txt ") to align: "))
   (setq ENTS (ssget Filter))
   (cond
    ((and
       (setq ENTS (jlgg-SSToList ENTS))
       (setq ENTS
	(vl-remove-if-not
	 (function
	   (lambda (eDim / Code70)
	    (setq Code70 (cdr (assoc 70 (entget eDim))))
	    (and (= 6    (logand 6  Code70))
		 (= XorY (logand 64 Code70)))
	 ENTS
    (T
     (prompt (strcat "\nNot Selected dimensions (" XorY-Txt ") to align: "))
     (setq ENTS nil)
  );; while
  (command "OSMODE" 0)
  ;;Aling Dims:
  (AlignTextDims ENTS)
  (command "OSMODE" OSPRE)
(princ)
