10:06 PM
Sorry , My English is not good
As I do not yet know how to code properly in LISP
Can help me add text misplacement?
Same as the picture
thank very much!!!
(defun C:OrdinateDimAlign (/ OSPRE eDimBase ENTS Filter XorY XorY-Txt ;|Functions|; GetX GetY jlgg-SSToList GetDimOrdinateType AlignTextDims ) ;;-------------------------- jlgg-SSToList ------------------------------- ;; selection set to list of entities ;;------------------------------------------------------------------------ (defun jlgg-SSToList (ss / ssl n) (if (and ss (= (type ss) 'PICKSET)) (repeat (setq n (sslength ss)) (setq ssl (cons (ssname ss (setq n (1- n))) ssl)))) );c.defun ;;;_______________________________________________________________________________________________________ ;; Returns "HOR" value of a point from an entities data record (defun GetX (eDimBase ANUM) (cadr (assoc ANUM (entget eDimBase)))) ;;;_______________________________________________________________________________________________________ ;; Returns "VER" value of a point from an entities data record (defun GetY (eDimBase ANUM) (caddr (assoc ANUM (entget eDimBase)))) ;;;_______________________________________________________________________________________________________ ;;; Determines if dims are horizontal or vertical (defun GetDimOrdinateType (eDimBase / Code70) (setq Code70 (cdr (assoc 70 (entget eDimBase)))) (if (= 64 (logand 64 Code70)) (setq XorY 64 XorY-Txt "Abscissa") (setq XorY 0 XorY-Txt "Ordinate") ) ) ;;;_______________________________________________________________________________________________________ ;;; Aligns dims (defun AlignTextDims (LstCotas / ) (mapcar (function (lambda (eDim / NewPt EntLst) (setq NewPt (cond ((= XorY 0 ) (list 14 (GetX eDimBase 14) (GetY eDim 14) 0.0)) ((= XorY 64) (list 14 (GetX eDim 14) (GetY eDimBase 14) 0.0)) ) ) ;(princ "\nPT = ")(princ NewPt) (setq EntLst (entget eDim)) ; Sets EntLst to data record of ENTA ;(princ "\nENTLST = ")(princ EntLst) (setq EntLst (subst NewPt (assoc 14 (entget eDim)) EntLst)) ; Substitutes new point for DXF# 14 ;(princ "\nENTLST = ")(princ EntLst) (entmod EntLst) ; Submits list to modify entity name contained in the list ) ) LstCotas ) );defun ;;-------------------------- MAIN -------------------------- (command "CMDECHO" 0) (setq OSPRE (getvar "OSMODE")) (setq Filter (list '(0 . "DIMENSION"))) ;;Imputs user: (while (not eDimBase) (prompt "\nSelect base Ordinate dimension to align to: ") (cond ((and (setq eDimBase (ssget "_:S:E" Filter)) (setq eDimBase (ssname eDimBase 0)) (= 6 (logand 6 (cdr (assoc 70 (entget eDimBase))))) ;; = OrdinateDimension ;;(vl-some (function (lambda (x) (= (cdr x) "AcDbOrdinateDimension"))) (entget eDimBase))) ) ) (T (prompt "\nNot selected Ordinate dimension..") (setq eDimBase nil) ) ) ) ;;; Determines if dims are horizontal or vertical: (GetDimOrdinateType eDimBase) ;;_______________________________________________________ ;; Selects dimensions to align to base (while (not ENTS) (prompt (strcat "\nSelect dimensions (" XorY-Txt ") to align: ")) (setq ENTS (ssget Filter)) (cond ((and (setq ENTS (jlgg-SSToList ENTS)) (setq ENTS (vl-remove-if-not (function (lambda (eDim / Code70) (setq Code70 (cdr (assoc 70 (entget eDim)))) (and (= 6 (logand 6 Code70)) (= XorY (logand 64 Code70))) ) ) ENTS ) ) ) ) (T (prompt (strcat "\nNot Selected dimensions (" XorY-Txt ") to align: ")) (setq ENTS nil) ) ) );; while (command "OSMODE" 0) ;;Aling Dims: (AlignTextDims ENTS) (command "OSMODE" OSPRE) (princ) )
