opening a lisp file within acad2015.lsp
hello
I'm trying to make adjustments in multiple drawings by using "acad2015.lsp". The file should contain commands and also different lisp files. I have a problem with those lisp files. They don't open or work. when I use them manually in the drawing they work fine. The command I tried to open them with "acad2015" was something like: _APPLOAD "adjust.lsp".
anyone a suggestion? 😄
found the solution!
How about sharing the solution?
Kent1Cooper
[As a general rule, it is advisable not to edit the ACAD####.lsp file in any version, but rather to put such things in an ACADDOC.lsp file, or something else that gets loaded from the Startup Suite in APPLOAD, or some other approach.  You can Search around here for various threads that explain all the reasons why.]
Kent Cooper, AIA
