Open, Plot, Close a specific drawing
Message 1 of 9
I am trying to create a custom command/button that will open a specific drawing, plot it with a saved page setup, then close it. Does anyone know of a macro, script, or lisp that may do this?
Note: This is a typical drawing that we use to print binders for our drawing packages and just want a quick way to allow users to print when they need a binder.
Replies (8)
Message 2 of 9
hak_vz
(defun C:bpp (/  file)
(setq file "C:/Drawing1.dwg" )
(command "_.fileopen" file)
(command "-.plot") ; follow command input and follow switches
; for ex
;(command "-.plot"  "y" ........
(command "close" file)
Miljenko Hatlak
Message 3 of 9
cadffm
Menu macro:
Ever tried to write your own?
For example by command -Publish and a predefined puplish list?
And yes, there are many ways, thats just of them.
Sebastian
Message 4 of 9
cadffm
Sebastian
Message 5 of 9
maratovich
Give us an example of your .dwg file.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 6 of 9
I have written many. This simple task seems to have me stuck.
Message 7 of 9
This lisp will open the drawing but will not plot and close. Note: 17x22 is the page setup saved to the drawing. Any suggestions?
(setq file "C:/Binders.dwg" )
(command "-.plot" "n" "17x22" "17x22"  "n" "n" "y" )
Message 8 of 9
cadffm
I posted one possible solution..
You can start a new AutoCAD instance with a script parameter, for example.
And for Using PLOT command inside the current program session
you have to fight with the SDI (= 1).
Sorry, time out, i am out. 😀
Sebastian
Message 9 of 9
Sea-Haven
Way to short check what it does when you do manually.
 (COMMAND "-PLOT"  "Y"  "" "DWG To PDF"
	       "Iso full bleed A3 (420.00 x 297.00 MM)" "m" "LANDSCAPE"  "N"   "W"  "-6,-6" "807,560" "1=2"  "C"
	       "y" "Acad.ctb" "Y"	"n" "n" "n" pdfName "N" "y"
