Open Explorer 2 Folder Levels Up From Current Directory
thomasarpasi
Message 1 of 11
thomasarpasi
I'm looking to open Explorer 2 Folder Levels Up From Current Directory via lisp.  I've created a number of LISP using block insertion and scripting, but this has me at a standstill.
I have getting the current directory down using dwgprefix.  How do I tell it go back 2 levels in reference to the dwgprefix variable?  I have done alot of searching and nothing has helped.  My approach may be off?  I've tried applying vl-string-trim-right and have had no luck as well.
Thanks in advance.
Replies (10)
Message 2 of 11
Kent1Cooper
If you're looking to open a drawing in that folder 2 levels up, here's one approach that seems to work:
;|  DwgUp2Folders.lsp [command name: DU2F]
  To open a Drawing in the Folder Up 2 levels from the current one
  Kent Cooper, 20 April 2022
(defun C:DU2F (/ prerev)
  (setq prerev (reverse (vl-string->list (getvar 'dwgprefix))))
  (vla-activate
    (vla-open
      (vla-get-documents
        (vlax-get-acad-object)
      (getfiled
        "Select drawing:"
        (vl-list->string
          (reverse (member 92 (cdr (member 92 (cdr prerev)))))
        "dwg" 0
(prompt "\nType DU2F to open a Drawing Up 2 Folder levels from current.")
If instead you only want to open the folder in Windows Explorer or something, you should at least be able to incorporate the same method of getting that folder name into a version of your current-directory code.
Kent Cooper, AIA
Message 3 of 11
hak_vz
Something like this:
Opens Explorer two levels up from current file path.
It doesn't check if removing two sub-directories will jump over root i.e C:, so you can try to implement that check.
(defun twodirsup ( / string_to_list ret)
	(defun string_to_list ( str del / pos )
		(if (setq pos (vl-string-search del str))
			(cons (substr str 1 pos) (string_to_list (substr str (+ pos 1 (strlen del))) del))
			(list str)
	(setq ret "")
	(foreach e 	(reverse(cddr(reverse (string_to_list (vl-filename-directory (getvar 'DWGPREFIX)) "\\"))))
		(setq ret (strcat ret e  "\\"))
	(startapp "Explorer" ret)
	(princ)
Miljenko Hatlak
Message 4 of 11
ВeekeeCZ
(defun c:Explorer2Up () (startapp "explorer" (strcat (getvar 'dwgprefix) "..\\..")) (princ))
Message 5 of 11
thomasarpasi
It seems to jump to "Documents" folder.  Not sure why...could be something on my end.
Message 6 of 11
thomasarpasi
Message 7 of 11
hak_vz
When directory to jump from is not too deep it will show you "Documents" since jumping two levels up passes over root. Code would have to be updated to so that it can work only with paths deeper than 3 levels.
Miljenko Hatlak
Message 8 of 11
ronjonp
@thomasarpasi
@ВeekeeCZ  Code worked fine here.
Message 9 of 11
john.uhden
My turn...
   (defun @str2list (str pat / i j n lst)
     (cond
       ((/= (type str)(type pat) 'STR))
       ((= str pat)'(""))
       (T
         (setq i 0 n (strlen pat))
         (while (setq j (vl-string-search pat str i))
           (setq lst (cons (substr str (1+ i)(- j i)) lst)
                 i (+ j n)
         (reverse (cons (substr str (1+ i)) lst))
;; This is the primary function:
(defun @up2 ( / a b c)
  (setq a (getvar "dwgprefix"))
   ;; "G:\\Projects-Cadd\\2019\\19190.Dewing.Mantoloking\\"
  (setq b (@str2list a "\\"))
   ;; ("G:" "Projects-Cadd" "2019" "19190.Dewing.Mantoloking" "")
  (setq c (reverse (cdr (cdr (reverse (vl-remove "" b))))))
   ;; ("G:" "Projects-Cadd")
  (apply 'strcat (mapcar '(lambda (x)(strcat x "\\")) c))
"G:\\Projects-Cadd\\"
John F. Uhden
Message 10 of 11
Sea-Haven
My take not deeply tested, pick any level.
; string to list by John Uhden
;  by John Uhden modified by Alan H April 2022
     (cond
       ((= str pat)'(""))
       (T
                 i (+ j n)
;; (setq a "G:\\Projects-Cadd\\2019\\projects\\1910\\19190.Dewing.Mantoloking\\")
  (setq lst '() x 0 str (strcat (nth 0 b) "/") )
  (setq lst (cons str lst))
  (repeat (- (length b) 2)
    (setq x (1+ x))
    (setq str (strcat str (nth x b) "/"))
  (setq lst (reverse lst))
  (setq lst (cons "Choose directory " lst))
  (if (not AH:Butts)(load "Multi Radio buttons.lsp"))
  (setq ans (ah:butts but "V" lst))
  (setq ans  (vl-string-translate "/" "\\" ans))
  (startapp "explorer" ans)
(princ)
Can set default button 2 up if required
Message 11 of 11
ronjonp
You could also do this easily in Windows Explorer. It's one more click though. 😃
