Only SOLID hatching in the background - lisp
pavel
Message 1 of 23
pavel
I need help figuring out how to change the order of SOLID hatches to the background so that they are at the very bottom. And most importantly, I need it to work on blocks and dynamic blocks. Thank you very much for your ideas. Ideally, a Lisp solution.
Replies (22)
Message 21 of 23
ВeekeeCZ
Removed by the user.
Message 22 of 23
pavel
Thank you, but this does not work for me either. In the end, I modified the LISP with the help of AI, and it works on blocks as well as on isolated solid hatches.
Message 23 of 23
paullimapa
I executed HSTB.lsp on your "solid in block.dwg" and it works fine just as I posted previously successfully moving the solid hatch pattern inside the block to the back without a need to use the AI generated VL functions.
I then made a copy of your "solid in block.dwg" and called it "solid in block & solid not in block.dwg" (attached) which now included an exploded version of the same block so that there's now a separate hatch solid pattern by itself.
This time I executed SOLIDHATCHTOBACK.lsp which handles both solid hatch patterns inside as well as outside of blocks just as @BlackBox_ & I posted previously and once again all solid hatch patterns are successfully moved to the back.
I've include a video demonstrating this as well as both lisp functions in case you get confused by previous postings.
Paul Li
IT Specialist
@The Office
