OLE to Excel from AutoCAD
jayhar
Advisor Advisor
jayhar
I have received an autocad file with excel file inserted on it. How can I extract to excel file from autocad OLE ?
Have any AutoLISP ??
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
cadffm
The thread of the original file owner with the original file, is located here: LINK TO ANOTHER THREAD
curious..
@jayhar
There are no excel informations, only a stupid picture (if i am right), so you can only rebuild
this part of table by converter software what try to re-build from raster data 2 excel.
Competion one: Create a pdf in good quality of that table.
A good typist achieves the result faster and in perfect (excel) quality.
(PS: I would send it to India, where tasks are done quickly and cheaply)
Sebastian
roland.r71
curious..
@jayhar
Indeed. Pretty awkward.
As for the OLE object: There's a difference between embedded & linked.
If the object is embedded, the objects is completely available within the dwg and can be edited. (separate from its source!)
If it's linked (as is the case here), the objects is only available as "grapical representation" and you need the original document to edit it.
Linked is used for 3 reasons:
1: it saves on the filesize, as the OLE object is not completely loaded into the dwg.
2: it allows for 1 source document to be edited and updates where linked.
3: without the source, the info can not be copied or edited (which prevents third parties from doing so !)
Trying to still export a linked OLE object, is like reverse engineering. (without the owners consent)
So, keeping point 3 in mind, sending it to india as pdf to have somebody recreate the excel...
that's like sending your iPhone to China and have it torn apart and build anew. I'm guessing Apple will not like you very much ... Smiley Wink
The only right way is to ask whomever created it if they could be so kind to share the source file.
Only if there is no source file available & you do have the rights to do so, having somebody recreating it becomes a (finall) option.
1 Copy from Autocad, paste it on Microsoft Word
2 Now copy again from Word and now you can paste Autocad Entities with PASTESPEC on Autocad
3 Can use Table Export lisp to export table to an Excel spreadsheet
Want more?
Repeat 1 and convert the Word into PDF
2 Open it in adobe acrobat and export it to an Excel spreadsheet (also works with online converters such as IlovePDF)
3 This is the best option to keep the format
lakshmikanthr22
This worked for me! Now stuck at running this lisp. How to run this lisp? what's the command? I opened a looked inside found "TE" but that didn't generate any csv or xls.
tarslanZ6AC6
Community Visitor
Community Visitor
TABLEEEXPORT
