- Mute
- Permalink
- Report
Hi, I have a lisp routine to trim all excess from arcs on interlocks at intersections. I use it to draw puzzle dies (see picture below).
(defun C:TRIMP-2 (/ cmde ssarc ssline ptlist arcno arcname cent radius
stang eang pt1 pt2 oldpick oldsnap)
(setq cmde (getvar "CMDECHO") ;save old variables
oldpick (getvar "PICKBOX")
oldsnap (getvar "OSMODE")
;WARNING: the routine only trims arcs on layer cle. To work on other layers
; remove the "(8 . "cle")" from the next line.
ssarc (ssget '((0 . "ARC") (8 . "cle"))) ;get set of arcs
arcno (sslength ssarc)
(setvar "CMDECHO" 0) ;turn off command prompts
(setvar "PICKBOX" 0) ;turn down pick box
(setvar "OSMODE" 0) ;turn off osnaps
; we need to find points on the free ends of the arcs to feed
; to the trim command.
(while (> arcno 0)
(setq arcno (1- arcno) ; decrement counter
arcname (ssname ssarc arcno) ; get name of arc
cent (cdr (assoc 10 (entget arcname))) ; get the center
radius (cdr (assoc 40 (entget arcname))) ; get the radius
stang (cdr (assoc 50 (entget arcname))) ; get the start angle
eang (cdr (assoc 51 (entget arcname))) ; get the end angle
pt1 (cal "cent+[radius<r2d(stang)]") ; get the start point
pt2 (cal "cent+[radius<r2d(eang)]") ; get the end point
ssline (ssget "C" (cal "cent-2*[radius,radius]")
(cal "cent+2*[radius,radius]") '((0 . "LINE"))) ;get set of lines
;if the block is not at the pt1 end
(if (= (sslength (ssget "C" (cal "pt1-[0.0001,0.0001]") (cal "pt1+[0.0001,0.0001]"))) 1)
(command "TRIM" ssline "" pt1 "") ;trim this end
(command "TRIM" ssline "" pt2 "") ;otherwise use the other end
(setvar "CMDECHO" cmde) ;restore old vars
(setvar "PICKBOX" oldpick) ;turn down pick box
(setvar "OSMODE" oldsnap) ;turn off osnaps
(princ)
(defun C:AA (/ l)
(setq l (getvar"CLAYER"))(setvar "CLAYER" "cle")
(command ".INSERT" "*A" pause "" 0)(setvar "CLAYER" l))
(defun C:BB (/ l)
(command ".INSERT" "*A" pause "" 270)(setvar "CLAYER" l))
(defun C:CC (/ l)
(command ".INSERT" "*A" pause "" 180)(setvar "CLAYER" l))
(defun C:DD (/ l)
(command ".INSERT" "*A" pause "" 90)(setvar "CLAYER" l))
(defun C:A8 (/ l)
(command ".INSERT" "*A" pause 0.8 0)(setvar "CLAYER" l))
(defun C:B8 (/ l)
(command ".INSERT" "*A" pause 0.8 270)(setvar "CLAYER" l))
(defun C:C8 (/ l)
(command ".INSERT" "*A" pause 0.8 180)(setvar "CLAYER" l))
(defun C:D8 (/ l)
(command ".INSERT" "*A" pause 0.8 90)(setvar "CLAYER" l))
(defun C:A6 (/ l)
(command ".INSERT" "*A" pause 0.6 0)(setvar "CLAYER" l))
(defun C:B6 (/ l)
(command ".INSERT" "*A" pause 0.6 270)(setvar "CLAYER" l))
(defun C:C6 (/ l)
(command ".INSERT" "*A" pause 0.6 180)(setvar "CLAYER" l))
(defun C:D6 (/ l)
(command ".INSERT" "*A" pause 0.6 90)(setvar "CLAYER" l))
It sometimes works, but most of the time it doesn't. Here's the message I get:
Command: TRIMP-2
Select objects: Specify opposite corner: 20 found
Select objects:
Invalid window specification.
; error: Function cancelled
Select object to trim or shift-select to extend or
[Fence/Crossing/Project/Edge/eRase]: Specify opposite corner:
Does not intersect with the cutting edge.
Specify opposite corner: *Cancel*
Command: *Cancel*
Command: Specify opposite corner or [Fence/WPolygon/CPolygon]:
