Offset Both Sides, erase originals
ВeekeeCZ
Consultant Consultant
Message 1 of 12
ВeekeeCZ
Hello... simple question about VL.
Digging into Lee Mac's code... I just want to make a minor change.... what is (vla-delete ss) for? Why this does not erase the original objects? What should I change to do that? Thx.
(defun c:edb () (c:ebd))
(defun c:ebd ( / *error* of undo doc ss ) ;Ekv Both
  (defun *error* ( msg )
    (and undo (vla-EndUndomark doc))
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
    (princ))
  (if (and (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*LINE")))
           (setq of (getdist "\nSpecify Offset Distance: ")))
    (progn
      (setq undo (not (vla-StartUndomark (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))))))
      (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc))
        (mapcar (function (lambda (o) (vl-catch-all-apply (function vla-offset) (list obj o))))
                (list of (- of))))
      (vla-delete ss)
      (setq undo (vla-EndUndoMark doc))))
  (princ)
Replies (11)
Message 2 of 12
Ranjit_Singh
    (princ))
    (progn
                (list of (- of)))(vla-delete obj))
  (princ)
Message 3 of 12
ВeekeeCZ
Thanks Ranjit,
sure, that is obvious... but still, why there was (vl-delete ss)? What it could be good for in the original code?, HERE
Message 4 of 12
patrick_35
Hi
the (vla-delete ss) clear the selection set.
Indeed, after several uses ssget, if not systematically deletes the selections, it was a mistake at some point.
A topic here
Message 5 of 12
rkmcswain
Reference
Message 6 of 12
Hi Guys,
I dont know much about Lisps and dont know how to program but I have used them and they have helped me a lot. Usually I just copy them and paste them into the command line, and viola!
I dont seem to get this one right. It gives me this "(_>" and dont allow me to give any input.
Please help this Lisp is exactly wat I need to make a weeks job into a minute job.
Thanks Guys!
Rossouw
Message 7 of 12
ВeekeeCZ
Well, then don't! Read about the proper way how to load a lisp HERE
Use this code... I've made minor changes in the code.
(vl-load-com)
(defun c:OffsetBothErase ( / *error* of undo doc ss )
    (princ))
    (progn
                (list of (- of)))
        (vla-delete obj))
  (princ)
Message 8 of 12
Thanks for the lesson BeekeeCZ.
Works like a charm!
Message 9 of 12
Kent1Cooper
@Anonymous wrote:
.... It gives me this "(_>" and dont allow me to give any input.  ....
That indicates that it's one short of the right number of closing right parentheses to finish up the command definition.  Did you perhaps just miss the last line with its single  )  in copying/pasting?
But this revival has inspired me to finish working out my own version of such a thing that I had started on some time ago, the attached OffsetBothSidesErase.lsp with its OBSE command.  Benefits over the routines already on this thread:
1.  It also works with Rays.
2.  It prevents selection of things on locked Layers [the other ones allow them, and if all things on unlocked Layers are processed before any on locked Layers, it doesn't matter, but encountering one on a locked Layer stops the routines, and any remaining things on unlocked Layers are not processed].
3.  It remembers your specified Offset distance [separately from regular Offset's], and offers it as the default on subsequent use, so you don't have to specify it again each time.  On first use [when you haven't specified a distance yet], if regular Offset's setting is other than "Through," it offers that as the default.
Kent Cooper, AIA
Message 10 of 12
BJanecka
Observer
Observer
I realize this is an older thread but hoping someone is willing to help.  I need to keep the original in Kent1Cooper's lisp instead of having it deleted.  I'm not familiar with writing lisp so I'm not sure what needs to change in his file.  Any suggestions on what all needs to be deleted from the file to keep the original?
Message 11 of 12
Kent1Cooper
Just take out this line:
          (vla-delete obj)
[And I would suggest changing the file and command names, and the commentary at the top, too.]
Kent Cooper, AIA
Message 12 of 12
BJanecka
Observer
Observer
Thank you
