ObjectIDtoObject
ObjectIDtoObject
john.uhden
Mentor Mentor
Message 1 of 13
ObjectIDtoObject
john.uhden
I'ved used that method plenty in 2002, but Civil 3D 2014 is giving me...
"; error: Exception occurred: 0xC0000005 (Access Violation)
; warning: unwind skipped on unknown exception"
It seems to not matter whether I use (vlax-invoke ...) or (vla-ObjectID...).
Does this method no longer work?  Must I go back to chasing 330 codes?
John F. Uhden
Replies (12)
Message 2 of 13
Ranjit_Singh
Message 3 of 13
john.uhden
That's insane.  This is AutoLisp.  What can be the difference between 42 and a function that evaluates to 42?!
John F. Uhden
Message 4 of 13
Ranjit_Singh
I would imagine that's the way the contract of objectIDtoObject works. If you see the error, it states access violation. Somehow the access is only provided when accessing it through the vla-getobjectid function. Just a guess.
Message 5 of 13
john.uhden
Well of course you need the ObjectId function to get the ID, but it's still 42 (in your example).  It's just an evaluation.
I mean no big deal; if that's the rule I can live with that.  It's just stupid.
Sam:  "Knock 3 times so I know it's you."
Fred:  Knocks 3 times.
Sam:  "No, you idiot.  Not like that.  Use the (knock) function!"
John F. Uhden
Message 6 of 13
dgorsman
Might want to do some checking; the object ID returned on a 64-bit system might be a long rather than an INT.  Maybe test with 42.0?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 7 of 13
Ranjit_Singh
I agree. You might say (eval objid) is the same as the integer 45, but this specific function does not see it like that. if objid is the pointer to subject object id then even this works
Command: (vla-objectidtoobject (vla-get-activedocument (vlax-get-acad-object)) (eval objid))
#<VLA-OBJECT IAcadLWPolyline 000000004714da48>
just like
Command: (vla-objectidtoobject (vla-get-activedocument (vlax-get-acad-object)) objid)
but this does not work
Command: (vla-objectidtoobject (vla-get-activedocument (vlax-get-acad-object)) 45)
So technically you do not need the objectID function, as long as you pass some symbol that evaluates to the objectID
Command: (vl-symbolp 'objid)
T
Command: (vl-symbolp 'eval)
T
Command: (vl-symbolp '45)
nil
Command: (vl-symbolp 45)
nil
Message 8 of 13
john.uhden
Knock 3 times if you need me.
OR...
If you need me, I'll give you a call.
OR...
"All of you who believe in telekenesis, raise my hand"
John F. Uhden
Message 9 of 13
john.uhden
Hi, Ranjit.
I was just thinking... there must be some difference between what the objectid or ownerid property returns to AutoLisp vs. what it returns to the objectidtoobject function, or maybe how AutoLisp interprets the evaluation.
Maybe it's actually a long integer that AutoLisp takes as a short integer.  I dunno; just thinking is all.
John F. Uhden
Message 10 of 13
Ranjit_Singh
Pick a polyline
(itoa (vla-get-objectid (vlax-ename->vla-object (car (entsel)))))
(itoa 45) definitely does not return thatSmiley Happy
Command: (vla-objectidtoobject *adoc* 45)
Command: (itoa (vla-get-objectid (vlax-ename->vla-object (car (entsel))))) Select object: "8796083183968" Command: (vla-objectidtoobject *adoc* 8796083183968) #<VLA-OBJECT IAcadLWPolyline 0000000074e8a438>
Message 11 of 13
john.uhden
I should have been more forward with my objective.  I actually want to freeze. layers by picking objects.  No, not necessarily the layer of the object returned by (entsel) nor by the object returned by (nentsel), but in between.  If a line on layer "0" is embedded in a block named "X" that is inserted in layer "1" in an xref, then I want to freeze layer "xref|1."  I thought the OwnerId was the path to take, but alas it takes you to the block record table, not the reference.
To complicate things more, block "X" might be inserted on layers "1" "2" and/or "3" in the xref.  Or even block "X" might be inserted into block "Y" on layers "4" "5" and/or "6" in the xref.  I probably don't want to freeze layer "0."
I guess I need a (parents) or (ancestors) function.
John F. Uhden
Message 12 of 13
_gile
You can use nentsel. If the selected entity is nested an is not an attribute reference, the last item of the returned list is the list of the ancestors.
In your example, this list should contain 2 items: the X block reference ename and the xref ename.
A little example:
(defun getAncestors (/ nent elst)
  (if (setq nent (nentsel))
    (cond
      ((cadddr nent))
      ((= "ATTRIB" (cdr (assoc 0 (setq elst (entget (car nent))))))
       (list (cdr (assoc 330 elst)))
(mapcar '(lambda (ent) (cdr (assoc 8 (entget ent)))) (getAncestors))
About the ObjectId, this behavior is due to the fact on a 64-bit AutoCAD the ObjectIds are coded with 64-bit integers and AutoLISP only have 32-bit integers so it cannot return the value as an integer (as it does with 32-bit AutoCAD versions).
Gilles Chanteau
GileCAD
GitHub
Message 13 of 13
john.uhden
You know, I am stupider than I look.  I had just looked back to some very old code of mine, and there it was.
Thank you, @_gile for confirming something I had already known but just forgot after 18 years.  I feel much better now.
John F. Uhden
