AutoLisp Shell command on Win 10 system
peter_thomson
peter_thomson
Hi there,
Wrote a bit of code last night for plotting to a PDF but want to kill Adobe Reader programmatically if the file has already been plotted to a PDF AND is open in Adobe Reader. part of this code is to run a dos batch file from a shell command but it requires the use of the old 8.3 filepath/filename system for lisp to find and run the file. Like this....
(command "shell" "C:/Progra~1/MWHGlO~1/APCADT~1/Plotting/KILL_A~1.BAT")
Is there anything I should know about how things run in Win 10 that might affect how I write this code? It works beautifully in Win 7.
If not, there must be something i missed on that system..
Thanks in anticipation,
Peter T
Dunedin, New Zealand.
C3D 2015, Win 7 Enterprise
I just tried the following and it worked for me -
(if (setq FN (findfile "D:/C-Drive/Bat/Folder1234567890/SetNone.bat"))
(command "shell" FN)
Note - I used the full path name and not the '~'
You can set your publish options to not open the pdf after creation...
peter_thomson
Thanks for that. I presume you are on a Win 10 system?
I wonder if the fact that you set a variable and then used that in the shell command is enough to make the difference?
Will give it a go today.
cheers, Peter
peter_thomson
yes thanks, I am aware of this, however, it is not part of the issue I am trying to solve immediately.
regards, Peter
peter_thomson
Thanks to all for your responses.
Looks like DOS is DOS no matter what version of Windows you are running.
Seems like the system I was testing on is faulty.
Cheers, Peter
