Object selection with color
Philip-John
Philip-John
I found a lisp by Lee Mac (see below link) to select objects by color and it's fine.
object select by color
Can anybody modify the same lisp to select objects within a selection only, and not the entire drawing?
dlanorh
Find this section in the lisp and insert the blue text. This will comment out the red text allowing it to be "re-instated" should that be required later. If you want to make it permanent just remove "_X"
           (sssetfirst nil
               (ssget ;(ssget "_X"
                   (if l
                       (list
I am not one of the robots you're looking for
Philip-John
Thanks a lot dlanorh,
Your solution is working. But it is not working if there no selection. Can you make it select objects in entire drawing if there is no selection.
Thanks & regards
Philip John
dbhunia
Try this ......
(defun c:SelectByColour ( / c d e l )
(princ "\nSelect objects from which you want to filter your objects....")
(ssget)
   (if (setq e (car (entsel "\nSelect the Colour to Filter...")))
       (progn
           (setq c
               (cond
                   (   (cdr (assoc 62 (entget e)))   )
                   (   (abs (cdr (assoc 62 (tblsearch "LAYER" (cdr (assoc 8 (entget e)))))))   )
           (while (setq d (tblnext "LAYER" (null d)))
               (if (= c (abs (cdr (assoc 62 d))))
                   (setq l (cons "," (cons (cdr (assoc 2 d)) l)))
           (sssetfirst nil
               (ssget "_p"
                   (if l
                       (list
                           (cons -4 "<OR")
                               (cons 62 c)
                               (cons -4 "<AND")
                                   (cons 62 256)
                                   (cons 8 (apply 'strcat (cdr l)))
                               (cons -4 "AND>")
                           (cons -4 "OR>")
                       (list (cons 62 c))
   (princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Philip-John
Thank you dbhunia and
