Object Data Table Export
townest
townest
I have built a simple Object Data table and wish to export it an most any form, but preferable just a plain old csv.  How, if possible, is the best way to access the Object Data table?
Thank you!
Tyler
CodeDing
@townest ,
Can you post a sample dwg please? and provide more details? That will help us look for a solution with you.
Best,
~DD
townest
@CodeDing To my knowledge there is only one Object Data Table in ACAD that I know of anyway... see https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/CloudHelp/cloudhelp/2019/EN....
townest
These object data tables are funny animals.  AutoCAD only ever shows what MS Access would call the 'Design View' or ArcGIS would call 'Field View' where the fields are shown but not the data.  The actual data table is latent as near as I can tell.   The closest you get to seeing real data is in the properties dialogue box one object at a time.  Hopefully there's a cool way to get the Object Data Table for all or selected objects out of the dwg.
Cheers,
Tyler
braudpat
Hello @townest
For me, you are into the "wrong" forum !
-------- AutoCAD MAP Forum --------
https://forums.autodesk.com/t5/autocad-map-3d-forum/bd-p/85
---- Additions for Object Data ----
https://forums.autodesk.com/t5/autocad-map-3d-forum/additions-for-object-data/td-p/7548282
Into this topic (please see above) there are the most important available Routines for ACAD MAP / ACAD CIVIL related to Object Data !
Most of them come from a Super ACAD Map French Developper Bruno (Pseudo : @CAdaSchtroumpf) !
Please see the attached Lisp File ... The Routine OD&PROP2CSV is THAT you need ! ... and much more ...
If you have problem with French , please let me know, I will translate it !
I have added an other beautiful Routine from Bruno : ROD
You must use it on objects with ODs attached ... Please fly over these objects ... And appreciate ROD !
THE HEALTH (Stay Safe), Regards, Patrice (The Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
CodeDing
@townest ,
I don't have time to mess with it right now, but..
- Here is some online documentation for the ADE_OD... functions
- And attached is some documentation that I have lying around that I use.
Best,
~DD
braudpat
Hello @CodeDing
Thanks for this old MAP Lisp function tutorial !
Patrice BRAUD
