convert / export layout to / as a block definition
jtm2020hyo
Message 1 of 8
jtm2020hyo
is there any AutoLISP to convert / export layout to / as a block definition?
Accepted solutions (3)
Replies (7)
Message 2 of 8
Moshe-A
@jtm2020hyo  hi,
hope this still actual? 😀
Attached EXPLAY (Export to Layout) command to export the current layout to file and than bring it in as standard block.
you must be in layout in order the command will work.
the block name will be the layout name and if the block is already exist, it will update it automatically.
is this what you had in mind?
enjoy
Moshe
; Export to layout than bring it as standard block
(vl-load-com)
(defun c:EXPLAY (/ savAttreq savAttdia fname bname)
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (setq savAttreq (getvar "attreq"))
 (setq savAttdia (getvar "attdia"))
 (setvar "attreq" 0)
 (setvar "attdia" 0)
 (cond
  ((= (getvar "tilemode") 1)
   (vlr-beep-reaction)
   (princ "\nthis command only work from layout.")
  ); case
  ((setq fname (getfiled "Export Layout to Model Space Drawing" (strcat (getvar "dwgprefix") (getvar "ctab")) "dwg" 1))
   (command "._exportlayout" fname)
   (setq bname (vl-filename-base fname))
   (setvar "expert" 5)
   (command "._-insert" (strcat bname "=" bname))
   (command); escape
   (setvar "expert" 0)
   (princ (strcat "\n" bname " is now standard block."))
  ); case
 ); cond
 (setvar "attdia" savAttdia)
 (setvar "attreq" savAttreq)
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
); explay
Message 3 of 8
jtm2020hyo
thanks a lot, MR. @Moshe-A , you saved me again.
Message 4 of 8
jtm2020hyo
is it possible that it can be automatically saved to the block list?
Message 5 of 8
Moshe-A
@jtm2020hyo ,
the lisp insert the layout block as a standard block and it shows in block list
Message 6 of 8
jtm2020hyo
I mean without user intervention. something like just leave to the user use the command and automatically add to block list with the Layout name adding (1) or (2) if repeat.
Message 7 of 8
Moshe-A
@jtm2020hyo ,
Attached the fix.
About blocks name:
EXPLAY adds (nnn) as suffix to block name as basic format, example:
you have "ground plan" layout, the block would be "ground plan(1)" if "ground plan(1)" block is not already exist.
if you have "ground plan(1)" layout, the block would be "ground plan(1)" again if "ground plan(1)" block is not already exist. if it is? the block would be "ground plan(2)" ....etc.
the program search Layout name for the parentheses and the number inside and use it as index to increment. the max number is limited to 2 power 7 (up to 128) to prevent infinite loop.
this declares in code as:
; declare constants
(setq UPTO (expt 2 7)) ; (= 128)
if you find this as limitation, you can set a higher power value like (expt 2 😎  increase it to 256 😀
the program will exit if suffix is not a numeric value. rename the layout to resolve this.
enjoy
Moshe
(vl-load-com) ; load ActiveX support
(defun c:EXPLAY (/ bname_generator ; local function
                   UPTO ERRMSG savAttreq savAttdia fname bname)
 ; block name generator
 (defun bname_generator (LayoutName / is_numeric gen_bn ; local functions
                                      p0 p1 suff)
  (defun is_numeric (suf)
   (vl-every
    '(lambda (c)
      (and (>= c 48) (<= c 57))
    (vl-string->list suf)
   ); vl-every
  ); is_numeric
  (defun gen_bn (layN j / bn)
   (while (and
            (< j UPTO)
            (tblsearch "block" (setq bn (strcat layN "(" (itoa j) ")")))
    (setq j (1+ j))
   ); while
   (if (< j UPTO)
     bn
  ); gen_bn
  (cond
   ((and
     (setq p0 (vl-string-position (ascii ")") LayoutName 0 t))
     (setq p1 (vl-string-position (ascii "(") LayoutName 0 t))
    (setq suff (substr LayoutName (+ p1 2) (- p0 p1 1)))
    (if (not (is_numeric suff))
     ERRMSG
     (gen_bn (vl-string-right-trim (strcat "(" suff ")") LayoutName) (1+ (atoi suff)))
    ); if
   ); case
   ( t
    (gen_bn LayoutName 1)
  ); cond
 ); bname_generator
 ; here start EXPLAY command
 ; declare constants
 (setq ERRMSG "illegal value found inside layout name parentheses.")
 (setvar "attreq" 0)
 (setvar "attdia" 0)
 (cond
   (vlr-beep-reaction)
  ); case
  ((not (setq bname (bname_generator (getvar "ctab"))))
   (vlr-beep-reaction)
   (princ (strcat "\nReached suffix limits, upto " (itoa UPTO) " is allowed, block is not created"))
  ); case
  ( t
   (if (eq bname ERRMSG)
    (progn
     (vlr-beep-reaction)
     (princ ERRMSG)
    ); progn
    (progn
     ; depending on layout 'volume' and computer speed
     ; next code lines may suspend autocad process
     ; for a while, without echoing to your screen - patience...
     (setq fname (strcat (getvar "dwgprefix") bname))
     (setvar "expert" 5)
     (command "._-insert" bname)
     (command); escape
     (vl-file-delete (strcat fname ".dwg"))
     (setvar "expert" 0)
    ); progn
   ); if
  ); case
 ); cond
 (princ)
); explay
Message 8 of 8
Moshe-A
@jtm2020hyo
attached is an update after fine tuning. the external block is now written to the temp folder preventing from overwritten an existing file on you working directory.
and more...it turns out  that  EXPORTLAYOUT is not so clean and may get AutoCAD to stuck. if you see explay suspend for long, go to task manager and 'kill' AutoCAD than do a good clean to the file and try again.
cheers,
Moshe
