I need a lisp to Update Polygon Object data "SUN_NO" Data Auto Update from polygon Overlapping text.
Refer Attached Image. i need a lisp to do this work
Solved by hak_vz. Go to Solution.
Solved by CADaSchtroumpf. Go to Solution.
Attach sample DWG.
Miljenko Hatlak
Look into Object Data Functions
The data is not exposed to Vanilla cad, i can not even run a test. perhaps anyone with Civil 3D or Autoacd MAP 3D can have a look
I don't use Civil 3d.
See @pbejse post about Object data functions. Here is my code that links text data to appropriate Mpolygon object
You just have to add appropriate function instead princ statement that prints text values to console.
(princ (strcat "\n" tv))
(defun c:SETMPDATA nil (SETMPDATA))
(defun SETMPDATA (ss j pts tv);
(defun getmpolypoints (e / ent p0 i pp ret pts)
(setq ent (entget e) p0 (cdr (assoc 11 ent)) i 0)
(repeat (length ent) (setq pp (nth i ent))(if (eq (car pp) 10) (setq ret (append ret (list (cdr pp))))) (setq i (+ i 1)))
(foreach pt ret (setq pts (cons (mapcar '+ p0 pt) pts)))
(cdr (reverse pts))
(setq ss (ssget "_x" '((0 . "MPOLYGON"))) j 0)
(repeat (sslength ss)
(setq pts (getmpolypoints(ssname ss j)))
(setq tv (cdr (assoc 1 (entget (ssname(ssget "_CP" pts '((0 . "*TEXT"))) 0)))))
(setq j (+ j 1))
(princ)
Miljenko Hatlak
At my side it works OK. I'll check it later today, and try to write additional data to create data record. I need to look inside Autolisp reference for CIV 3d or MAP.
I hope you know some basic autolisp scripting and testing.
Miljenko Hatlak
With your sample drawing, this can be to work's
(defun c:text2OD_mp ( / v e l lst ll p ent_po vla_obj ent1_off ent2_off lst1_pt lst2_pt lst_pt js kmod)
;; by ElpanovEvgeniy
;; convert MPolygon to Lwpolyline
;; version 0.2
;; 2012.07.11
;; mailto: elpanov@gmail.com
;; web: elpanov.com
(while (not (setq v (ssget "_+.:E:S" '((0 . "MPOLYGON"))))))
(setq
e (entget (cadar (ssnamex v)))
v (cons 0 (mapcar (function -) (cdr (assoc 11 e)) (cdr (assoc 10 e))))
l
(vl-remove nil
(list
'(0 . "LWPOLYLINE")
'(100 . "AcDbEntity")
(assoc 67 e)
(assoc 410 e)
(assoc 8 e)
(if (assoc 63 e)
(cons 62 (cdr (assoc 63 e)))
(if (assoc 421 e)
(cons 420 (cdr (assoc 421 e)))
'(100 . "AcDbPolyline")
lst e
ll nil
(defun f (l i)
(if (> i 0)
(cons (mapcar (function +) (car l) v) (f (cdr l) (1- i)))
(while (setq lst (member (assoc 93 (cdr lst)) (cdr lst)))
(setq p (f (cdr lst) (cdar lst))
ll (append ll (list '(92 . 7) '(72 . 0) '(73 . 1) (car lst)) p '((97 . 0)))
(entmakex (vl-remove nil (append l (list (cons 90 (cdar lst)) '(70 . 1)) p (list (assoc 210 e)))))
(setq vla_obj (vlax-ename->vla-object (setq ent_po (entlast))))
(vla-Offset vla_obj 1.0)
(setq ent1_off (entlast))
(vla-Offset vla_obj -1.0)
(setq ent2_off (entlast))
(entdel ent_po)
(setq
lst1_pt (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget ent1_off)))
lst2_pt (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget ent2_off)))
(if (> (distance (cdr (assoc 11 e)) (car lst1_pt)) (distance (cdr (assoc 11 e)) (car lst2_pt)))
(setq lst_pt lst1_pt)
(setq lst_pt lst2_pt)
(entdel ent1_off) (entdel ent2_off)
(setq js (ssget "_WP" lst_pt '((0 . "TEXT") (8 . "Text"))))
(sssetfirst nil js)
(cond
((and js (eq (sslength js) 1))
(initget "Yes No")
(setq kmod (getkword "\nProcess selection [Yes/No]? <Yes>: "))
(if (or (eq kmod "Yes") (not kmod)) (setq kmod "Yes") (setq kmod "No"))
(cond
((eq kmod "No")
(princ "\nAbandon")
(T
(ade_odsetfield (cdar e) "SUN" "SUN_NO" 0 (cdr (assoc 1 (entget (ssname js 0)))))
(sssetfirst nil nil)
(prin1)
"You just have to add appropriate function instead princ statement that prints text values to console"
What I Need to Add ...😊
@shil143 wrote:"You just have to add appropriate function instead princ statement that prints text values to console"
Something like
(ade_odsetfield (ssname ss j) "SUN" "SUN_NO" 0 tv))))
Miljenko Hatlak
Still Same Error ...... ; error: too few arguments
@hak_vz Thanks For Your Valuable Time...I Got Solution from @CADaSchtroumpf
@shil143You have received your solution and that's what all is about.
I have worked with Mpolygon for a first time, managed to decipher how data are stored, recreated its boundary..., andhopped it will work. So no time is wasted. 🙂
Miljenko Hatlak
Hello @CADaSchtroumpf
1) THANKS and as usual a Beautiful routine !
2) Please is it possible to have the same routine with standard 2D LWPolylines (NOT MPolygon !) and a Text inside ?
Because a Lisp routine will be easier / faster to use than some "special" MAP Features !
THE HEALTH, Regards, Patrice
Patrice BRAUD
@braudpat Try this:
(defun SETMPDATA ( / ss j pts tv);
(defun getmpolypoints (e / ent p0 i pp pts)
(repeat (length ent) (setq pp (nth i ent))(if (eq (car pp) 10) (setq pts (append pts (list (cdr pp))))) (setq i (+ i 1)))
pts
(setq ss (ssget "_x" '((0 . "*polyline"))) j 0)
(setq fieldname (getstring "\nField name >"))
(ade_odsetfield (ssname ss j) "Desc" fieldname 0 tv)
(setq j (+ j 1))
(princ)
Eventually check how ade_odsetfield is defined. In my previous post I forgot / in function definition and it generated an error.
Miljenko Hatlak
Hello @hak_vz
THANKS for your routine : it is very short !
I have changed the tittle and added very minor things ...
;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/object-data-string-update-from-text/td-p/9819766
;; Routine: Text2ODPol by hak_vz
;; Copy TEXT INSIDE closed PLine to an OD Field (MAP or CIVIL required)
;; ATTENTION : NO Error Management !
;; (defun c:SETMPDATA nil (SETMPDATA))
(defun c:Text2ODPol nil (SETMPDATA))
(defun SETMPDATA ( / ss j pts tv) ;
pts
;; (setq ss (ssget "_x" '((0 . "*polyline"))) j 0)
(setq ss (ssget '((0 . "*polyline"))) j 0)
;;;;;; Warnings ;;;;;;
(princ "\nPlease give the CORRECT Name for the OD Table AND the OD Field ! " )
(princ "\nALL 2D PLines selected must ALREADY have the right OD Table attached ! \n" )
(setq ODTableName (getstring "\nOD Table Name > "))
(setq ODFieldName (getstring "\nOD Field Name for the TEXT inside > "))
;; (ade_odsetfield (ssname ss j) "Desc" ODFieldName 0 tv)
(ade_odsetfield (ssname ss j) ODTableName ODFieldName 0 tv)
(setq j (+ j 1))
(princ)
Patrice BRAUD
Hello @shil143 @hak_vz @CADaSchtroumpf
1) First I have removed "MY"solution because I am almost "null" in Lisp/AutoLisp
The Lisp routine (related to Polylines) is 99.99% from @hak_vz !
2) I have tried to update the @CADaSchtroumpf routine (related to MPolygons)
but WITHOUT success !!
;; New Lines to get the 2 Names ... WHERE I have to insert these 2 Lines ???
;; It seems to be wrong just after the defun !!
-- Original line from Mr CADaSchtroumpf :
-- Changed to :
(ade_odsetfield (cdar e) ODTableName ODFieldName 0 (cdr (assoc 1 (entget (ssname js 0)))))
3) What do you mean by >>> Can You Change to Multiple Object Selection <<<
Do you want a general purpose routine for MPolygons, 2D Closed PLines, Cercles ??
THANKS in advance for your help !
Patrice BRAUD
@braudpat I would help but have no access Civil 3d or MAP 3d.
From Googling results I've get that formulation is
(ade_odsetfield x table y 0 z)
where x is the entity name; table is the table name; y is the field name; 0 is the record number; z is the value for the field.
Consult this link for Autocad MAP 3D Autolisp reference
Miljenko Hatlak
