object count per layer
Message 1 of 10
thank you all. this lsp is count objects per layer all dwg.
I want to  add (ssget). specify a selection area.
;; Layer Count  -  Lee Mac
;; Prints a report of the number of objects on each layer in a drawing
(defun c:layercount ( / lst )
    (vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
        (vlax-for obj blk
            (setq lst (layercount:assoc++ (vla-get-layer obj) lst))
            (if
                (and
                    (= "AcDbBlockReference" (vla-get-objectname obj))
                    (= :vlax-true (vla-get-hasattributes obj))
                (foreach att (vlax-invoke obj 'getattributes)
                    (setq lst (layercount:assoc++ (vla-get-layer att) lst))
    (princ (layercount:padbetween "\n\n" "" "-" 62))
    (princ (layercount:padbetween "\nLayer" "Objects" " " 61))
    (princ (layercount:padbetween "\n" "" "-" 61))
    (foreach itm (vl-sort lst '(lambda ( a b ) (> (cdr a) (cdr b))))
        (princ (layercount:padbetween (strcat "\n" (car itm)) (itoa (cdr itm)) "." 61))
    (princ (layercount:padbetween "\nTotal" (itoa (apply '+ (mapcar 'cdr lst))) "." 61))
    (textpage)
    (princ)
(defun layercount:assoc++ ( key lst / itm )
    (if (setq itm (assoc key lst))
        (subst (cons key (1+ (cdr itm))) itm lst)
        (cons  (cons key 1) lst)
(defun layercount:padbetween ( s1 s2 ch ln )
        (lambda ( a b c )
            (repeat (- ln (length b) (length c)) (setq c (cons a c)))
            (vl-list->string (append b c))
        (ascii ch)
        (vl-string->list s1)
        (vl-string->list s2)
(vl-load-com) (princ)
Replies (9)
Message 2 of 10
pbejse
Try the modified attached lisp file [ layercount.lsp ]
snip:
(ssget)
	    (progn
		    (vlax-for obj (setq ss (vla-get-ActiveSelectionSet (vla-get-activedocument (vlax-get-acad-object))))
HTh
Message 3 of 10
thank you pbejse for your concern.
sorry but I really don't understood.
like this
(ssget)
 (progn
     (vlax-for obj (setq ss (vla-get-activedocument (vlax-get-acad-object))))
          (vlax-for obj blk
            (if
                (and
 ) ; progn
error message : bad argument type: #<VLA-OBJECT IAcadDocument 000002330467aca8>
Message 4 of 10
CAD-Heinz
Hallo
Have that synonymous times tested but get an error message
Habe das auch mal getestet bekomme aber eine Fehlermeldung
Befehl: LAYERCOUNT
Objekte wählen: Entgegengesetzte Ecke angeben: 4 gefunden
Objekte wählen:
; Fehler: Fehlerhafter Argumenttyp: VLA-Objektsammlung: #<VLA-OBJECT IAcadDocument 000002e3ac422658>
Befehl:
DH
Message 5 of 10
pbejse
@CAD-Heinz wrote:
Hallo
Oops, thought i attached the file on my previous post. sorry about that.
Message 6 of 10
CAD-Heinz
Thanks works perfectly
Danke funktioniert perfekt Smiley Happy
DH
Message 7 of 10
oh that is perfect.. thank you.
Message 8 of 10
pbejse
Good for you, Glad i was able to help.
Lee Mac should take the credit for this,  kudos to LM Smiley Happy
Message 9 of 10
dusty_g
I've been using this program for a while and it has worked great.  Thanks again to Lee Mac.  I would like to adjust it but not familiar with the VLA commands, so I'm not sure how to do it.   What I would like is to have the counts per layer divided by 2 when it lists the object total.  So for example, there are 30 items on a layer, I would like it to divide by 2 and have it list 15 for that layer.  We need it to do this for some manufacturing process counts.
Any help/guidance would be appreciated, I'm sure it's pretty easy.  Let me know if you need further explanation.
Message 10 of 10
stev98312
Is there an easy way to alphabetize the layer list, rather than order by object count?
Steve
