NURBS Equations evaluation, De Boor's algorithm with Autolisp
_Bilal
Message 1 of 16
_Bilal
How to evaluate the NURBS Equations, De Boor's algorithm by Autolisp?
I checked this forum to see if the topic has been addressed before, but I did not find anything relevant.
However, here is the code.
; * Nurbs@u		Evaluates the coordinates of a point on a Nurbs curve (Spline)
; *				Simulates the function 'vlax-curve-getPointAtParam
; *				#Author	-  _Bilal
; * p			[int]  the degree of the curve.
; * @u			[Real] the parameter value of the knot vector at a specified point
; * ulst		[List] the knot vectors as sequence of parameter values
; * plst		[List] the list of control points of the Nurbs curve
(defun Nurbs@u ( p @u ulst plst / addlist nips i clst )
	;This function Adds the atoms(sublist) in the list (lst)
	;the atoms are a sublist of reals numbers like a point.
	(defun addlist ( lst / v )
		(setq v (car lst))
		(while (setq lst (cdr lst)) (setq v (mapcar '+ v (car lst))))
	);end
	;Loop over plst
	(setq i 0 clst nil)
	(repeat (length plst)
		(if (setq nips (Nips@u i p @u ulst)) (setq clst (cons nips clst)))
		(setq i (1+ i))
	(addlist (mapcar '(lambda (c p) (mapcar '(lambda (x) (* c x)) p)) (reverse clst) plst))
);Endof//Nurbs@u
; * Nips@u		The B-spline basis functions used in the construction of NURBS curves
; *	i			[int] Corresponds to the ith control point
; * p			[int] Corresponds with the degree of the basis function.
; * @u			[Real] The parameter value of the knot vector at a specified point
; * ulst		[List] The knot vectors as sequence of parameter values
(defun Nips@u ( i p @u ulst / f@u g@u Bin@u i@u binlst n b1 b2 bin bin+ niplst )
	(defun f@u ( i p @u ulst / dn )
		(if (= (setq dn (- (nth (+ i p) ulst) (nth i ulst))) 0.0) 0.0 (/ (- @u (nth i ulst)) dn))
	);end
	(defun g@u ( i p @u ulst / dn )
		(if (= 0.0 (setq dn (- (nth (+ i p 1) ulst) (nth (+ i 1) ulst)))) 0.0 (/ (- (nth (+ i p 1) ulst) @u) dn))
	);end
	(defun i@u ( p @u ulst / i imx )
		;Initial values
		(setq i 0 imx (- (length ulst) p 2))
		;Is @u within the knots domain definition?
		(if (<= (car ulst) @u (nth (1+ imx) ulst))
			(if (= @u (nth (1+ imx) ulst)) imx (while (<= (nth (1+ i) ulst) @u) (setq i (1+ i))))
	);end
	(defun Bin@u ( i p @u ulst / i* iu binlst )
		(if (setq iu (i@u p @u ulst))
			(progn
				(setq i* i binlst nil)
				(While (<= i* (+ i p))
					(setq binlst
						(if (= i* iu)
							(cons (list i* 0 1.0) binlst)
							(cons (list i* 0 0.0) binlst)
					(setq i* (1+ i*))
				;Retval
				(reverse binlst)
	);end
	;Loop
	(if (setq binlst (Bin@u i p @u ulst))
		(repeat p
			(setq n 0 niplst nil)
			(setq binlst
				(reverse
					(repeat (1- (length binlst))
						(setq b1 (nth n binlst) b2 (nth (setq n (1+ n)) binlst))
						(setq i (car b1) p (1+ (cadr b1)) bin (caddr b1) bin+ (caddr b2))
						(setq bin (list i p (+ (* (f@u i p @u ulst) bin) (* (g@u i p @u ulst) bin+))))
						(setq niplst (cons bin niplst))
	;Retval
	(caddar binlst)
);Endof//Nips@u
;+++++++++++++++++         DEMONSTRATION        ++++++++++++++++++++++
; * grSpline		GRDRAW an spline
; * st				[int] Spline status Clamped, Closed...
; * p				[int] Spline degree  1-2-3--5-6 .... 10
; * ulst			[list] List of Knots vectors u0 u1 .... um
; * plst			[list] List of control points in WCS
; * ns				[Real] Number of segments for each knot vectors
; *					(precision for curve presentation)
; * +++++++++++   FOR EXAMPLE  ++++++++++++++++
; * +++++  Let say we have the following data
	(setq p 3 st 0 ns 10) Clamped opened curve of degree 3
	(setq plst
		'(	(74.8 96.5 0.0) (105.6 51.6 0.0) (163.7 130.5 0.0) (209.8 130.6 0.0)
			(252.3 85.2 0.0) (310.1 223.9 0.0) (111.3 237.4 0.0)
	m=n+p+1=7+3+1=11	m:length of ulst  n:number of control points p:degree
	(setq ulst '(0.0 0.0 0.0 0.0 1.0 2.0 3.0 4.0 4.0 4.0 4.0))
	Now, Grdraw the Spline curve according to the above data
	(grSpline st p ulst plst ns)
(defun grSpline ( st p ulst plst ns / imx @umx n du @u pt )
	;Initial values
	(setq imx (- (length ulst) p 2))
	(setq @umx (nth (1+ imx) ulst) n (length plst) du (/ (apply 'min (vl-remove 0.0 ulst)) ns))
	;Nurbs status
	(cond
		;Uniform Non-Rational Nurbs (Clamped)
		((= st 0) (setq @u (nth 0 ulst)))
		;Uniform Non-Rational Nurbs (AutoCAD Closed)
		((= st 1) (setq @u (nth 0 ulst)))
		;Uniform Non-Rational Nurbs (Opened)
		((= 2 st)) ;Not applicable at moment
		;Uniform Non-Rational Nurbs (Closed)
		((= 3 st) (setq @u (nth (1- p) ulst)))
	;Loop over Knots vectors
	(setq pt (Nurbs@u p @u ulst plst))
	(while (< (setq @u (+ @u du)) (+ @umx du))
		(if (> @u @umx) (setq @u @umx))
		(cond
			((vl-position st '(0 1)) (grdraw pt (setq pt (Nurbs@u p @u ulst plst)) 1))
			((= 2 st))
			((= 3 st)
				(if (< (nth (1- p) ulst) @u (nth (+ n (* -2 p) 1) ulst))
);Endof//grSpline
The above code is based on the form shown in the figure
Replies (15)
Message 2 of 16
diagodose2009
Please you develope full-mathematical-C+ script.
You can convert anyime this script to 100%autolisp.
I need help , for develope math-algorthms , you do not develop autolisp-algorithms.
You can convert anytime , you can convert math-algorithims script to 100%Visual-lisp.
(clickhere "youtu.be/cuBbQ6K45YY?t=12") (You search setq-z80 inside description)
You see description isinside youtube, watcher only firefox.exe
Together we need mathematically algorithms..for must be sure your -programe.cpp+programe.lsp, have more future  in 2022year.
Best Regards..
Message 3 of 16
hak_vz
@_Bilal
Here you have my code related to Catmull-Rom spline. Simple principle can be applied to Nurbs curves.
Miljenko Hatlak
Message 4 of 16
stevor
Did not run it, but a syntax check :
about line 80, in (defun grSpline
it probably should be:
du (/ (apply 'min (vl-remove 0. ulst)) ns) ; revised
S
Message 5 of 16
hak_vz
@diagodose2009 Why not supply direct solution written in autolisp/visual lisp. This forum is about autolisp/visual lisp and not about conversion from c++ or anything else. Your software is great but this is not the point of this forum. What we looking fore is a simple code that can me human readable and can be used to beginner programmers to learn some codding techniques. Maybe I', wrong but I just see it that way.
Miljenko Hatlak
Message 6 of 16
leeminardi
As noted by @stevor , there's a problem in the line
	(setq @umx (nth (1+ imx) ulst) n (length plst)  (apply 'min (vl-remove 0.0 ulst)) du (/  ns))
; error: bad variable name in SETQ: (APPLY (QUOTE MIN) (VL-REMOVE 0.0 ULST))
For my better understanding of NURBS math I created a custom VBA/Excel B-spline function hoping to tackle the more complex NURBS math later. If the weight values for all the CVs of a NURBS spline equal 1 then the NURBS curve reduces to a B-spline.  The attached macro-enable Excel file includes the example data from your listing and a plot of the resulting curve.  The program uses the recursive deBoor algorithm to compute the coefficients for the B-spline function.   It successively duplicates the splines created in AutoCAD with the default weight of 1 for all CVs.
lee.minardi
Message 7 of 16
_Bilal
Thank you for your comment, I fixed now.
Message 8 of 16
_Bilal
The macro in your excel excel file is great, it do the same recursive calculation as in my code Nips@u and Nurbs@u posted here, but when I changed the curve degree from 3 to 5 in your excel file the recursive calculation doesnt works!!
Message 9 of 16
_Bilal
I saw your code two days ago, it's great.
Message 10 of 16
leeminardi
I think this version of the Excel/VBA B-spline  function should handle degree changes correctly.
lee.minardi
Message 11 of 16
_Bilal
The same problem exists in both versions!
Message 12 of 16
leeminardi
Can you post a copy of the file with the data you are using and note the degree you want to use?
lee.minardi
Message 13 of 16
_Bilal
I utilized the same data in the file, just I changed the degree from 3 to 5, the result as show in the figure (before/after)Nurbs-Excel.jpg
Message 14 of 16
leeminardi
Here's what I see.
Are you sure you have macros enabled?  The cells are showing that they don't recognize the custom function.
lee.minardi
Message 15 of 16
_Bilal
All right, it was my mistake, the macro was disabled, I enabled the macro and it is working now
Message 16 of 16
diagodose2009
Perhaps you build Applet.zip before the programs.Lisp.ascii was written.
