NUDGE command
NUDGE command
Message 1 of 24
NUDGE command
OK, I admit it. I haven't tried very hard to make this work. I have tried,
but one component is making it difficult for me, a novice lisp
writer/architectural drawing fool.
What I'm looking for is a freebie:
I used to use a mac & a program called "powercad". It had a command called
"nudge" which allowed you to preselect objects, then hit the 4 arrow keys to
move the selection set on the orthogonal axes.
the nudge amount is a preset (but variable) amount - and it's an incredibly
useful tool.
is there an acad friendly equivalent out there?
thanks for reading this far.
Replies (23)
Message 21 of 24
You can use (setenv) and (getenv) in R14 to write/read to the registry.
Jaysen
"Rune Wold" wrote in message
news:[email protected]...
> Here is a new version of my Nudge function. Added to the previous version
> is:
> -Smal changes to the dialog
> -Error handeling
> -Rotation
> -Offset and rotation values are saved to file
> As a lot of folks still are using R14, I use a file (c:\nudge.txt) to save
> the values instead of using the registry (and I don't like to use third
> party software like doslib if I can avoid it).
> Please let me know what you all think about it.
> Rune Wold
> e-mail: [email protected]
> tlf: +47 38 05 72 63
> fax: +47 38 05 71 76
Message 22 of 24
That's true; it writes the key/value to the FixedProfile\General key.
I forgot about that, thanks.
Matt
[email protected]
On Mon, 31 Jan 2000 10:10:26 -0800, "Jaysen Long"
Message 23 of 24
General FYI...
You can also organize values in subfolders of the FixedProfile\General key
using the following syntax:
(setenv (strcat "MyAppName\\" key) val)
and
(getenv (strcat "MyAppName\\" key))
as in the following utility functions:
(defun app:getenv (app key / ) (getenv (strcat app "\\" key)))
(defun app:setenv (app key val / ) (setenv (strcat app "\\" key) val))
Jaysen
"Matt Stachoni" wrote in message
> Matt
> [email protected]
Message 24 of 24
How to AutoCAD nudge (2017 edition)
1. Select line or block you wish to nudge.
2. Hold ctrl+ and arrow key
3. You are now nudging.
I need help;
my osnap setting got flipped around and set to my cad default to the grid snap, I was able to change my setting back to polar snapping but now my nudge is stuck on grid snapping and I have no idea how to turn it back to polar. If any one finds out how get the normal nudge back please tell me, I miss being able to nudge by my zoom and not this useless grid-snap-nudge.
