nparse function
nparse function
Moshe-A
Mentor Mentor
nparse function
Moshe-A
hi guys,
it's been a while since i visit here to give my help (soon i'll be back) but now i have one of my own  😀
i need a function to parse the value (coming from sysvar cannoscalevalue) and i like it to be recursive.
it's now getting 2 args:
1.  n (which is cannoscalevalue can be 0.1 0.01 0.001 etc and each iteration is multiplied by 10)
2.  s (each iteration it also multiplied by 10)
so here is what i have:
(defun nparse (n s)
 (cond
  ((>= n 1) s)
  ((nparse (setq n (* n 10)) (setq s (* s 10))))
uses: (nparse 0.01 1)
but i do not like the 1 arg for s to reset, wonder if someone can come up to a version to drop the 1.
thanks in advanced
Moshe
cadffm
I don't understand this limited function, what do you expect with this?
I am talking about your cannoscale sample ONLY.
cannoscalevalue is a factor, so you can have all floats reals and floats a value,
your functions works only for scalefactor less 1 and all greater one reverts 1 as value.
I can't understand what you want to do with this result / with this function?
I would understand a function like this:
(defun nparse (n / s)
 (/ 1.0 n)
Please take a minute to explain me, what you want to do with your function and
why you want a 1 if the scalefactor is greater than 1
and why you want 100 as result if the scalefactor is 0.02 for example.*
Sebastian
Moshe-A
wow, in 3 words @cadffm : YOU ARE BRILIANT 👋
(/ 1 n) just covers everything.
what i wanted to know is the actual running linetype scale as in my understanding when msltscale in on...in model space the actual ltscale is the annotation scale e.g :
(* (1 / (getvar 'cannoscalevalue)) (getvar 'ltscale))
Am i right?!
thank you very much
Moshe
dbroad
Like @cadffm , I'm puzzled.
(getvar "cannoscale") will get you the name for the current annotation scale.
(/ 1.0 (getvar "cannoscalevalue")) will get you the denominator of 1:n ratio of the current scale.
Example:
Command: (getvar "cannoscale")
"1-1/2\" = 1'-0\""
Command: (getvar "cannoscalevalue")
0.125
Command: (/ 1.0 (getvar "cannoscalevalue"))
8.0
So that is the same as a ratio of 1:8.0
Architect, Registered NC, VA, SC, & GA.
Moshe-A
@dbroad  hi,
it is not exactly the same,  (getvar "cannoscale") returns a string the name of the scale list defines in SCALELISTEDIT and you can not relay on that, users often make mistakes.
dbroad
I think I made it clear that they were different but related.  See the command return values.  All you needed was (/ 1 n) where n was the annoscalevalue.
