Change the ViewPort Scale
sundaram1087
sundaram1087
Hi
I am writing the script to create the drawings. In that i had an requirement for updating the VP Scale by script
I can able to change the VP Scale by manually but am not able to update it by command line method.  Please refer the following images for your reference
I have created the Custom Scales  like "SR-S0" in view port (Ref-Image1)
Initially it was set to SR-SO and then based on requirement i need to change that to SR-S1
For Change the scale i used the command "cannoscale". By using that command it scale get changed but the view port not updated. For that i need click the option that "Click to Synchronize" to update the view scale
Please suggest your thoughts how to overcome this issue
Thanks & Regards
Shunmugasundaram
Sea-Haven
I have the advantage of working in metric so this part is easy the viewport has a property "Customscale".
For metric customscale= 4 is 1:250 ie 1000/250 = 4.
So shoud be able to set the customscale to a imperial value. Make sure viewport is not locked as will will not work again lock is a property.
: DUMPIT
Select entity:
; IAcadPViewport 7a039e70 : TeighaX Interface of rectangular object created in paper space that display view
; Property values :
;   Application (RO) = #<VLA-OBJECT IAcadApplication 000000002D686F00>
;   ArcSmoothness = 1000
;   Center = (420.0 297.0 0.0)
;   Clipped (RO) = 0
;   Color = 256
;   CustomScale = 4.0
