No function definition: =nil error.
moreira.jose
moreira.jose
Hello, im making a small lisp to generate some 3d models, but i keep getting an error about not having "function definition".
Dont know why this is happening, if someone could point me in the right direction, please.
here is my code so far:
(defun c:cabinet ()
(setq 2dpoints (getvar "osmode"))
(setq 3dpoints (getvar "3dosmode"))
(setvar "osmode" 0)
(setvar "3dosmode" 0)
(setq pt1 (getpoint "what is the cabinet corner point: "))
(If (= nil
(setq wide (getreal "what is the cabinet lenght (in x):
(setq wide 1.9))
(if (=nil
(setq depth(getreal "what is the cabinet depth (in y): ")))
(setq depth 0.32))
(If (= nil
(setq height (getreal "what is the cabinet height (exterior in z): ")))
(setq height 0.45))
(If (= nil
(setq thick (getreal "what is the material section: ")))
(setq thick 0.02))
(model)
(model2)
(setvar "osmode" 2dpoints)
(setvar "3dosmode" 3dpoints)
(command "ucs" "")
(defun model ()
(command "ucs" pt1 "")
(command "box" (list 0 0 0) (list wide depth thick))
(defun model2 ()
(command "box" (list 0 0 thick) (list thick depth height))
cadffm
it is because of  ..... there is no function defined with the name  "=nil"
If you would use the VLIDE, you would find your typo easily 😉
=nil
vs.
= nil
OFFtopic
NOTE: All what is not true, is nil 😉
(or (setq wide (getreal "what is the cabinet lenght (in x):")))
      (setq wide 1.9)
Sebastian
moreira.jose
thank you... i feel like an idiot
cadffm
Everyone has experienced this 100 times 😂
Sebastian
ВeekeeCZ
Untested. See if that could be somehow inspiring.
(defun c:cabinet ( / :model :model2 2dpoints 3dpoints)
  (defun :model ()
    (command "box" (list 0 0 0) (list wide depth thick)))
  (defun :model2 ()
    (command "box" (list 0 0 thick) (list thick depth height)))
  (or *c-wide* 	(setq *c-wide* 1.9))  		; default setting
  (or *c-depth*	(setq *c-depth* 0.32))
  (or *c-height*(setq *c-height* 0.45))
  (or *c-thick*	(setq *c-thick* 0.02))
  (if (and (setq pt1 (getpoint "what is the cabinet corner point: "))
	   (setq *c-wide* (cond ((getdist "\nWhat is the cabinet lenght (in x) <" (rtos *c-wide*) ">: "))
				(*c-wide*)))
	   (setq *c-depth* (cond ((getdist "\nWhat is the cabinet depth (in y) <" (rtos *c-depth*) ">: "))
				 (*c-depth*)))
	   (setq *c-height* (cond ((getdist "\nWhat is the cabinet height (in z) <" (rtos *c-height*) ">: "))
				  (*c-height*)))
	   (setq *c-thick* (cond ((getdist "\nWhat is the  material section <" (rtos *c-thick*) ">: "))
				 (*c-thick*)))
    (progn
      (setvar "osmode" 0)
      (:model)
      (:model2)
      (command "ucs" "")))
  (princ)
Sea-Haven
Your welcome to modify this, very close.
; Getvals multi allows multiple line inputs with an image must be a slide image
; By Alan H Oct 2019
; code examples
; Example Code to use sldie name is furntable
; (if (not AH:getvalsimg)(load "Multi Getvals img.lsp"))
; (setq ans (AH:getvalsimg "D:\\Acadtemp\\furntable" 40 (list "Enter table size" "Enter length" 5 4 "1200" "Enter width" 5 4 "900" "Table thickness" 5 4 "30" "Enter height" 5 4 "900" "Enter Leg size" 5 4 "100")))
(defun AH:getvalsimg (img_name siz dcllst / x y num fo fname keynum key_lst v_lst)
(setq num (/ (- (length dcllst) 1) 4))
(setq x 0)
(setq y 0)
(setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w"))
;(setq fo (open (setq fname "d:\\acadtemp\\alantest.dcl") "w"))
(write-line "getvalsimg : dialog {" fo)
(write-line (strcat "label =  " (chr 34) (nth 0 dcllst) (chr 34) "  ; ") fo)
(write-line " : row {" fo)
(write-line "spacer ;" fo)
(write-line "  : column {" fo)
(write-line "  : icon_image { " fo)
(write-line (strcat "  width =" (rtos siz 2 0) " ;") fo)
(write-line "  aspect_ratio = 1.0 ;" fo)
(write-line  (strcat "key = " (chr 34)  "Ah_img"  (chr 34) " ;") fo)
(write-line "  }" fo)
(write-line " : boxed_column {" fo)
(write-line "  width = 22 ;" fo)
(write-line "spacer_1 ;" fo)
(repeat num
(write-line ": edit_box {" fo)
(setq keynum (strcat "key" (rtos (setq y (+ Y 1)) 2 0)))
(write-line (strcat "    key = " (chr 34) keynum (chr 34) ";") fo)
(write-line (strcat " label = " (chr 34) (nth (+ x 1) dcllst) (chr 34) ";") fo)
(write-line (strcat "     edit_width = " (rtos (nth (+ x 2) dcllst) 2 0) ";") fo)
(write-line (strcat "     edit_limit = " (rtos (nth (+ x 3) dcllst) 2 0) ";") fo)
(write-line "   is_enabled = true ;" fo)
(setq x (+ x 4))
(write-line "ok_only;}" fo)
(close fo)
  (setq dcl_id (load_dialog fname))
  (if (not (new_dialog "getvalsimg" dcl_id))
    (exit)
  (setq x 0)
  (setq y 0)
  (setq v_lst '())
  (repeat num
    (setq key_lst (cons keynum key_lst))
    (set_tile keynum (nth (setq x (+ x 4)) dcllst))
    (mode_tile keynum 3)
      (start_image "Ah_img")
      (slide_image  0 0 (- (dimx_tile "Ah_img") 1) (- (dimy_tile "Ah_img") 1) img_name)
      (end_image)
  (action_tile "accept" "(mapcar '(lambda (x) (setq v_lst (cons (get_tile x) v_lst))) key_lst)(done_dialog)")
  (start_dialog)
  (unload_dialog dcl_id)
  (vl-file-delete fname)
  (princ v_lst)
 your welcome to modify this to suit.
(setq len (atof (nth 0 ans))
wid  (atof (nth 1 ans))
thick (atof (nth 2 ans))
Ht (atof (nth 3 ans))
leg (atof (nth 4 ans))
