No Function Definition ACET-LAYTRANS
I have a button which automatically runs LAYTRANS with a specific standards file. Express Tools is loaded correctly.
If I open a drawing, load the lisp containing my command, my button returns this:
error: no function definition: ACET-LAYTRANS
If I run the original LAYTRANS command, cancel it, and then use my button, it works.
Does anyone know why LAYTRANS must be run first before ACET-LAYTRANS is treated as a defined function?
Or, how can I initialize LAYTRANS without running it and then canceling it?
Thanks in advance.
If you can figure out which ET file contains that command, load it prior to starting yours.
If you can't, then from Express Tools Help:
The library files for the AutoCAD Express Tools are not loaded at AutoCAD startup by default. This was done to reduce the time
needed to load AutoCAD. The libraries load the first time that an Express Tools command is issued, creating a delay the first time
you use an Express Tool in an AutoCAD session. You can use the EXPRESSTOOLS command to force the AutoCAD Express Tools libraries to
be loaded at the beginning of the AutoCAD session.
I wrote this blog post some days ago and found a reason to post it.
In short you need to load laytrans.arx
http://jtbworld.blogspot.com/2007/05/translate-layers-using-laytrans-on.html
Jimmy Bergmark
JTB World - Software development and consulting
Owner/Developer
http://www.jtbworld.com
JTB World offers you software's, custom software development, consulting...
http://www.jtbworld.com/about.htm
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
AutoCAD 2008
http://www.jtbworld.com/autocad2008.htm
"bbarkman" wrote in message news:5570664@discussion.autodesk.com...
this:
it works.
Thanks in advance.
Thanks to all who replied!
Problem solved with:
(cond ((not (member "laytrans.arx" (arx))) (arxload "laytrans")))
I followed this line with the one that runs my standard file. Works great.
