new layers from objects
jim78b
Message 1 of 10
jim78b
i have this lisp that convert all object colour and linetype in layers but don't work give me
; error: no function definition: VLA-GET-LTSCALE
(vl-load-com)
(defun c:classify ( / ss ssl index obj color linetype ltscale str layertable newlayername)
 (princ "\n select object to classify")
 (if (setq ss (ssget))
    (progn
      (setq ssl 0)
      (setq ssl (sslength ss))
      (setq index 0)
      (setq str "")
      (repeat ssl
        (setq obj (vlax-ename->vla-object (cdr (assoc -1 (entget (ssname ss index))))))
        (setq color (vla-get-color obj))
        (if (= color 256) ; if by layer
           (setq color (cdr (assoc 62 (tblsearch "LAYER" (vla-get-layer obj)))))
        (setq color (vl-princ-to-string color))
        (setq linetype (vl-princ-to-string (vla-get-linetype obj)))
        (if (= linetype "ByLayer") ; if by layer
           (setq linetype (cdr (assoc 6 (tblsearch "LAYER" (vla-get-layer obj)))))
        (setq linetype (vl-princ-to-string linetype))
        (setq ltscale (vl-princ-to-string (vla-get-ltscale obj)))
        (setq str (strcat "color-"color "_lt-" linetype "_lts-" ltscale))
        (setq layertable (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
        (if (= (tblsearch "LAYER" str) nil)
           (progn
             (setq newlayername (vla-add layertable str))
             (vla-put-color newlayername color)
             (vla-put-linetype newlayername linetype)
             (vla-put-ltscale newlayername ltscale)
           ); end of progn
        ); end of if
        (vlax-put-property obj 'layer str)
        (setq index (+ index 1))
      );end of repeat
    );end of progn
 );end of if
(princ)
);end of defun
Replies (9)
Message 2 of 10
ВeekeeCZ
Are you the author?
You should post some sample dwg to test.
I've fixed the obvious, didn't think it through in detail.
(vl-load-com)
(defun c:test ( / ss ssl index obj color linetype ltscale str layertable newlayername)
    (progn
      (setq ssl 0)
      (setq index 0)
      (setq str "")
      (repeat ssl
	(setq ltscale (vla-get-LineTypescale obj))
	(setq str (strcat "color-" (vl-princ-to-string color) "_lt-" (vl-princ-to-string linetype) "_lts-" (vl-princ-to-string ltscale)))
	  (progn
	    ); end of progn
	  ); end of if
	);end of repeat
      );end of progn
    );end of if
  (princ)
  );end of defun
Message 3 of 10
jim78b
NO i am not the author
Message 4 of 10
Sea-Haven
There is still 1 mistake will let you find it. When looking for stuff like Linetypescale use Dumpit.lsp to check for correct property name.
Message 5 of 10
jim78b
sorry i am not able to coding
Message 6 of 10
devitg
@jim78b Why not to start coding?
Message 7 of 10
jim78b
How many airs you give yourself.
if I knew how to program I would have given help without being argumentative
Message 8 of 10
Sea-Haven
What is wrong here, please this is for Jim78 only needs to learn so dont post correction.
(vla-get-LineTypescale newlayername ltscale)
Message 9 of 10
jim78b
Thanks i will try.
Have a good day and thanks for understanding.
Message 10 of 10
jim78b
sorry don't work in nested blocks
