New drawing from a template
charles_neelyFG4LK
charles_neelyFG4LK
I'm trying to get a new drawing from a template other than the default. Below is what I have. When I run it, hangs up w/ the path on the command line. If I press enter it creates a new dwg but with the default template.
;SheetCreation
(defun c:nft ()
(setq template(getstring "C:/WSB_ACAD Support/_C3D/2024/01_Templates/Civil-C3D-Styles-2024.dwt"))
(vla-activate (vla-Add (vla-get-Documents (vlax-get-acad-object)) template))
(princ)
Sea-Haven
Why not set your template as the default when you type New. Just do OPTIONS FILES TEMPLATE, set the Template name including path, set the Template path also.
The other way is use "OPEN" it works with dwt also.
(command "OPEN" "MYDWT")
ec-cad
Change:
To be:
(setq template "C:/WSB_ACAD Support/_C3D/2024/01_Templates/Civil-C3D-Styles-2024.dwt")
ECCAD
charles_neelyFG4LK
Thank you!! I appreciate the help!
