new_dialog position
new_dialog position
SAPER59
new_dialog position
SAPER59
I can't position the dialog any more in the desired position working with (new_dialog ndiag #TROG_DCL "" #pdd200) and
It always uses the center of the screen for new opened dialogs
Does something change in last AutoCAD versions or there's something to be set, to let it works as old versions.
Kent1Cooper
We can't tell without seeing what is setting your variables, and whether they are of the correct types.  The syntax from Help:
(new_dialog dlgname dcl_id [action [screen-pt]])
The dlgname argument needs to be a string, dlg_id an integer, [action can be your ""], and screen-pt a point list.
Kent Cooper, AIA
Sea-Haven
Thanks Kent tried it out. The offset looks like from top left corner, taking into account screen res values maybe.
(setq dcl_id (load_dialog fname))
(if (not (new_dialog "AHbutts" dcl_id "" (list 200 200)) )
(exit)
paullimapa
FYI: My experience with why the dialog position not sticking to where last closed even when that's built into the code has to do with running the AutoCAD window on the 2nd monitor and not the first.  Then the dcl will always appear in the center of the 2nd monitor. If you were to move the AutoCAD window back to the primary monitor, then the dcl window position will properly save and will appear in that location when reopening.
Paul Li
IT Specialist
@The Office
