change block scale
change block scale
CraigP_
change block scale
CraigP_
Why does this only change the scale of 1 block in the selection set?
There are 5 blocks in the drawing in question.
Coincidently it only scales the block whose name comes last alphabetically.
(defun c:TEST (/ sc)
  (setvar 'cmdecho 0)
 (setq ss (ssget "_X" '((0 . "INSERT") (2 . "BIOA1_v*,LNO_BHPB_A1,NW_BHPB*"))))
  (setq sc (getreal "\nSpecify scale [1/2/5/10/15/20/25]:"))
 (if ss
    (progn
      (setq blk (vlax-ename->vla-object (ssname ss 0)))
      (vlax-put-property blk 'XEffectiveScaleFactor sc)
      (vlax-put-property blk 'YEffectiveScaleFactor sc)
      (vlax-put-property blk 'ZEffectiveScaleFactor sc)
  (setvar 'cmdecho 1)
  (princ)
thanks
Craig
ВeekeeCZ
Look HERE  how to process a selection set
CraigP_
Thanks, I'll have a read and see how I go.
Craig
ronjonp
@CraigP_ You also don't need the cmdecho lines since you're not using command calls.
CraigP_
Thanks for this tip
Craig
